Belkin Mini Display port to DVI Adapter
£21.19
Delivery:
Standard: 1-3 working days
Key features
  • 5" adapter
  • Easy plug and play allows seamless display of your laptop and tablet content to an external monitor or projector
  • Molded-strain relief provides flexibility at the connection points
  • Video only. Need separate audio cable
  • Length: 12.7cm
  • Stock Status: In Stock
Product codes
Connect your laptop to an external monitor using this Mini DisplayPort to VGA adapter. The Belkin Mini DisplayPort to DVI adapter allows you to project content in 1080p high definition resolution from your laptop, or expand your workspace to include a larger monitor.
Product Description Belkin DVI adapter - 12.7 cm
Type DVI adapter
Features Molded, strain relief
Length 12.7 cm
Connector Mini DisplayPort - male
Connector (Second End) DVI-D - female
Compliant Standards Plug and Play
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Belkin Mini Display po...
£21.19
