Belkin MixIt Colour Range Micro USB Cable 2m - Black
£3.44
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • At a Glance: Plugs into any USB 2.0 port to charge portable devices
  • Syncs music and pictures to or from your laptop in seconds
  • Compatible with most devices with a Micro-USB port
  • Length: 2m
  • Stock Status: In Stock
Product codes
Charge and sync your Samsung Galaxy devices quickly and safely, using just one cable. Simply plug the USB end directly into any USB port to stay connected while you're at home, at work, or on the road.
Use the MiXiT UP Micro-USB to USB ChargeSync cable to charge and sync your Samsung at the fastest possible speed. The small, durable micro USB connector also works with most smartphones and tablets with a micro USB port.
The MiXiT UP ChargeSync cable plugs into any USB 2.0 port, so you can use it virtually anywhere. Connect to your laptop to charge and sync, use your own wall charger to charge from the wall, or plug into a car charger and charge on the road.
Product Description Belkin MIXIT USB cable - 2 m
Type USB cable
Features Sync and charge
Length 2 m
Connector 5 pin Micro-USB Type B - male
Connector (Second End) 4 pin USB Type A - male
Colour Black
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Belkin MixIt Colour Ra...
£3.44
