Belkin Portable Battery Power Pack 2000 with MicroUSB Cable -...
Belkin Portable Battery Power Pack 2000 with MicroUSB Cable - Black
£16.56
25 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Portable backup charging solution for your mobile device
  • Provides hours of charge with 2,000 mAh
  • Compatible with any USB-enabled device
  • One USB port
  • Type: Rechargeable
  • Size: Li-ion
  • Stock Status: In Stock
Product codes
Charge your smartphone - even when you can't get to a wall outlet. Portable, slim and lightweight, the Power Pack 2000 is the perfect way to ensure your battery won't run out when you're on the go. With 2000 mAh of power, it has the capacity to full charge a cell phone twice or a smartphone once.
A USB to micro-USB cable is included for both charging your battery and recharging the Power Pack. To charge, simply plug the micro-USB into your device and plug the USB into the power pack. A convenient charge indicator lets you know how much power is available. When it's time to recharge, just flip the cable and plug it into your computer or another power source.
Product Description Belkin Power Pack 2000 power bank
Product Type Power bank
Colour Black
Output Connector Type USB - on cable: Micro-USB
Battery 2000 mAh
Cables Micro-USB to USB cable - 15.2 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Belkin Portable Batter...
£16.56
