Experience the comfort, convenience, and quality of Belkin sound with the SoundForm True Wireless Earbuds. Meticulously crafted and designed for your active life, these IPX5-rated sweat and splash resistant earbuds provide comfort and protection from moisture. Get lost in enhanced deep bass and crystal clear mids and highs - at any volume - all while reducing outside interruptions with a comfortable and adjustable sealed in-ear fit. With intuitive touch controls and one-step Bluetooth pairing, these wireless earbuds are ideal for those on the go, at home, or at the office. The stylish and compact charging case provides an extended charge when you need it, up to 24 hours of playtime.
Product Description | Belkin SoundForm - true wireless earphones with mic | Product Type | True wireless earphones - Bluetooth | Recommended Use | Portable electronics | Colour | White | Headphones Form Factor | In-ear | Wireless Technology | Bluetooth | Manufacturer Warranty | 1-year warranty |
General | |
Product Type | True wireless earphones - Bluetooth - wireless |
Dimensions & Weight Details | Earphone: 10 g , Charging case: 3.65 cm x 7 cm x 3 cm / 43 g |
Colour | White |
Features | Touch control |
Protection | Sweat-resistant, IPX5 |
Audio Output | |
Connectivity Technology | Wireless |
Microphone | |
Form Factor | Built-in |
Connections | |
Connector Type | USB (micro-USB) |
Miscellaneous | |
Included Accessories | Charging case, 3 pairs of silicone ear tips (small, medium, large) |
Cable Details | Micro-USB cable - 15 cm |
Power | |
Battery | Headphone battery rechargeable |
Run Time (Up To) | 24 hour(s) |
Run Time Details | Continuous playback: up to 24 hours |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
