Belkin Universal In Car Cup Mount for iPhone & Smartphones
£28.69
36 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Mount smartphone in your car's cup holder
  • Rotates 360 degrees for portrait or landscape view
  • Tilt phone 90 degrees to lay flat
  • Base expands to fit any cup holder
  • Cable management prevents tangled cables
  • Stock Status: In Stock
Product codes
This cradle fits securely in your car's cup holder and safely positions your compatible iPhone, iPod touch, or Android smartphone within view - no suction cup or adhesive required.
The mount can be rotated 360 degrees so you can position your smartphone in either portrait or landscape mode. Portrait mode is ideal for charging, listening to music, and hands-free phone calls, while landscape view makes using your favorite navigation apps easier. You can also tilt the mount 90 degrees so your smartphone lies flat, keeping it out of the way of your car's controls.
The mount's base expands to fit any size cup holder, so you can use in any vehicle. And because there's no adhesive backing, you can easily move the Car Cup Mount between vehicles.
Product Description Belkin Car Cup Mount - car holder for mobile phone
Product Type Car holder
Intended For Mobile phone
Suitable For Installation Car
Designed For Apple iPhone 4, 4S, 5, 5s, 6, 6 Plus; Samsung Galaxy Note 3, Note II, S II, S4, S5
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Belkin Universal In Ca...
£28.69
