Belkin Universal Micro Car Charger for Apple Products - White
£13.14
Delivery:
Key features
  • Ultra-compact
  • Plugs into any car power outlet
  • 5 Watt/1 Amp
  • Universal powered USB port
Product codes
Charge your iPhone 5 on the road with the Belkin Car Charger with included Lightning to USB cable. Get unlimited play and standby time with the low-profile design that sits flush in your dash. Get unlimited play and standby time with the low-profile design that sits flush in your dash. Use the Car Charger with the included 4-foot lightning to USB cable to charge your iPhone 5, iPad or iPad mini at the fastest possible speed. The smaller, more durable lightning connector is also reversible, which makes plugging in it easier than ever. The USB Port is universal, so you can still charge your legacy Apple devices with a 30-pin cable or other devices that use a micro-USB cable. And the included 4-foot lightning to USB cable can be used anywhere - plug it into your laptop to charge and sync, or use your own wall charger to charge from the wall. Great as a replacement cable or if you simply need an extra. Low profile design fits easily in your dash. Rubber grips allow you to insert and remove your lightning car charger with ease. The lightning connector has a reversible design for quick and easy connections.
Product Description Belkin Car Charger car power adapter
Product Type Car power adapter
Colour White
Output Connector Type USB
Max Electric Current 1 A
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Belkin Universal Micro...
£13.14
