We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Wirelessly connect up to seven Bluetooth-enabled devices. The Belkin Mini Bluetooth V4.0 Adapter provides cable-free connections to devices up to 10 meters away indoors. This compact, stylish adapter is unobtrusive when plugged into a USB port, and draws minimal energy, so it's perfect to leave plugged in and take anywhere. It is also backward-compatible with legacy Bluetooth technology.
Product Description | Belkin USB 4.0 Bluetooth Adapter - network adapter - USB | Device Type | Network adapter | Form Factor | External | Interface (Bus) Type | USB | Weight | 2.2 g | Data Link Protocol | Bluetooth 4.0 | Data Transfer Rate | 3 Mbps | Frequency Band | 2.4 GHz | Compliant Standards | Bluetooth 4.0 | System Requirements | Microsoft Windows Vista / XP / 7 / 8 |
General | |
Networking | |
Connectivity Technology | Wireless |
Max Range Indoors | 10 m |
Aerial | |
Antenna | Internal |
Expansion / Connectivity | |
Connections | 1 x USB - 4 pin USB Type A |
Software / System Requirements | |
OS Required | Microsoft Windows Vista / XP / 7 / 8 |
Dimensions & Weight | |
Weight | 2.2 g |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
