Belkin USB-C™ 4-Port Mini Hub
£38.78
36 in stock
Delivery:
Standard: 1-3 working days
Key features
  • 2x USB-C Ports
  • 2x USB-A Ports
  • 5Gbps Data Transfer Speeds (shared)
  • Powered through USB-C host device
  • Tethered Type-C Cable for easy access
  • Ultra-portable / Slim design
  • Charge peripherals with 900mAh (shared)
Product codes
Connect your USB-C laptop, to multiple USB devices with this comprehensive port expansion hub. Two USB-C ports connect devices, while two USB-A ports allow easy connection for existing devices, such as a hard drive, mouse, keyboard or printer. Small and compact, with a tethered USB-C cable, the hub is an ultimately portable and comprehensive peripherals solution.
Connect all your peripherals to your USB-C device with one compact hub. Two USB-A ports connect existing devices, and two dedicated USB-C ports for newer peripherals. Existing or new, your keyboard, mouse, flash drive or cable to sync other devices, will all find a home with this compact hub.
Connect your devices to the hub to sync, and enjoy data transfer of 5 Gbps. That's fast by any standard, let alone a multi-tasking hub that's the size of a pack of playing cards.
Product Description Belkin USB-C 4-Port Mini Hub - hub - 4 ports
Device Type Hub - 4 ports
Subtype USB
Ports 4 x SuperSpeed USB 3.0
Features USB powered
Compliant Standards USB 3.0, USB 3.1
Colour Black
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Belkin USB-C™ 4-Port M...
£38.78
