Belkin VGA to DVI Smart Cable 6'
Key features
  • Coaxial VGA cabling supports superior image clarity
  • Ferrite bead reduces electromagnetic and radio frequency interference (EMI/RFI)
  • Strain relief molding increases durability
  • Double shielding and PVC overmolding prevent loss of data
  • PC99 color and modified thumbscrews allows for easy installation
  • All-in-one design makes connections and setups neat and easy
  • UL rated wiring
Product codes
Belkin Smart Cables connect between the Desktop Computer and the KVM. Once connected, the cable converts the video signal (VGA or DVI) from the PC to a compatible signal for the KVM. The KVM is now able to support mix platform environments. Belkin smart cables are fully compatible with Belkin KVMs.
The Belkin Smart VGA to DVI-D Cable connects to Belkin Advanced Secure DVI-I and Secure DVI-D KVM Switches and provides multi-platform support for desktop computers with an analog connection (VGA). It also converts analog (VGA) signals to digital in order to support Advanced Secure DVI-I and Secure DVI-D KVMs in conjunction with a digital (DVI-D) monitor.
Product Description Belkin Secure KVM Cable Kit - video / USB cable - 1.8 m - B2B
Type Video / USB cable
Length 1.8 m
Connectors 15 pin HD D-Sub (HD-15) - male , 4 pin USB Type A - male
Connectors (Second End) 24+1 pin digital DVI - male , 4 pin USB Type B - male
Manufacturer Selling Program Belkin B2B
Designed For P/N: F1DN102DEA, F1DN104B-3EA, F1DN104DEA, F1DN104W-3
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Belkin VGA to DVI Smar...
