Belkin WeMo Smart Light Bulb Starter Kit Bundle (Screw Type)
Key features
  • Turn your lights On/Off and dim them from anywhere
  • Lighting to match your mood
  • Control up to 50 WeMo smart led bulbs
  • Look like you're home, even when you're not
  • Easy to use, easy to install
Product codes
Turn lights on, off or dim individually or as a group -- from anywhere
Create custom schedules and control for your LED lights individually or as a group
Have your smart bulbs turn on a sunset or have them turn off at sunrise
Simulated Occupancy feature turns your lights on and off automatically making it look like you're home - even when you're not.
WeMo Smart LED Bulbs can gradually dim, so you can fall asleep in a more natural way
With the WeMo Lighting Starter Set you've already got everything you need: WeMo works with your existing home Wi-Fi network and mobile Internet (3G / 4G)
Modular system. You can add additional WeMo LED Light Bulbs easily, any time
Intuitive, easy set up and easy to use
Works with the entire family of Belkin WeMo products
Free WeMo App for Android, iOS and Kindle operating systems
Works with IFTTT, connecting you to a whole world of Web apps
WeMo works on multiple smart devices simultaneously
WeMo Smart LED Bulbs have a 23 year life expectancy
Bright, warm light similar to a 60W incandescent bulb
Two-year limited warranty
DEVICE COMPATIBILITY
Android smart devices running Android 4.0 or higher
iOS smart devices running iOS 6 or higher
iPod Touch 3rd Generation and later
iPhone 3GS and later
iPad 2 and later
iPad Mini
SYSTEM REQUIREMENTS
Wi-Fi Router with an internet connection
Either Android 4.0 or higher/ iOS 5 or higher
WiFi 2.4GHz 802.11n
WeMo App (downloadable from App Store, Google Play Store or Amazon App Store)
PRODUCT SPECIFICATIONS
Form Factor : A19
Connector Type : Screw type
Input Power : 230V
Beam Angle : >240°
LED Output Temperature: 3000K
LED Output Brightness : >800 Lumens (60 Watt Incandescent Equivalent)
Dimmable : 50 lumens/watt
Life: 25,000 hours L70
Communications : ZigBee running HA 1.2 supporting "Dimmable Light" clusters. Tested to 50 devices, capable of potentially 500.
Number of Power Outlets: 1
PACKAGE CONTENTS
2 WeMo Smart LED Bulbs
1 WeMo Link
WARRANTY
2 year Limited Warranty
Belkin WeMo Starter-Set - wireless lighting set - LED light bulb x 2
Wireless lighting set
Light Bulb Type
2 x LED light bulb
Total Wattage
19 W (equivalent 120 W)
Dimmer
Shape
A19
Socket Type
E27
Wattage
9.5 W
Wattage Equivalent
60 W
Colour of Illumination
Warm white light
Colour Temperature
3000 K
Luminous Power
800 lumens
Beam Angle
240 degree(s)
AC 220 - 240 V
Frequency Required
50 Hz
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Belkin WeMo Smart Ligh...
