Belkin Wireless N600 Dualband Router DSL (Cable Line)
Key features
  • MultiBeam TechnologyHigh-powered signal for multiple devices
  • Dual-Band SpeedUp to 300Mbps (2.4GHz) + 300Mbps (5GHz)
  • 1 USB PortFor wireless printing or storage
  • 4 Ethernet LAN PortsFor fast and reliable wired network connections
  • Easy SetupEASY START gets you set up in 3 easy steps
  • Preset SecuritySecurity settings are preset to get you up and running safely
Product codes
Advanced performance for video streaming and online gaming
Belkin's exclusive MultiBeam antenna technology gives you maximum throughput while minimizing dead spots for optimized video streaming from multiple devices, virtually anywhere in your home.
Dual-Band Speed
Get the fastest dual-band speeds for video streaming and online gaming--up to 300Mbps (2.4GHz) + 300Mbps (5GHz).*
1 USB Port
Connect an external hard drive for easy sharing of photos and files, or connect a printer for wireless printing from any computer in your home.
Preset Security
WPS/WPA2 encryption standards and preset security settings get you up and running safely. One-touch Wi-Fi Protected Setup (WPS) securely connects multiple computers and devices with the push of a button.
Easy Setup
Get your secure wireless network up and running in minutes. Just three easy steps, and you're you out of the box and onto the Web.
+4 Apps
Enhance your online activities with Belkin's integrated apps: SELF-HEALING, VIDEO MOVER, PRINT ZONE and MEMORY SAFE™.
*The standard transmission rates--300Mbps (for 2.4GHz), 300Mbps (for 5GHz), 54Mbps, and 11Mbps--are the physical data rates. Actual data throughput will be lower and may depend on the mix of wireless products used.
Product Description Belkin F9K1102 - wireless router - 802.11a/b/g/n - desktop
Device Type Wireless router - 4-port switch (integrated)
Enclosure Type Desktop
WAN Ports Qty 1
Data Link Protocol Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Frequency Band 2.4 GHz / 5 GHz
Data Transfer Rate 300 Mbps
Capacity Virtual interfaces (VLANs): 16
Network / Transport Protocol TCP/IP, PPTP, L2TP, IPSec, PPPoE
Routing Protocol Static IP routing
Remote Management Protocol HTTP, HTTPS
Features NAT support, Stateful Packet Inspection (SPI), Wi-Fi Protected Setup (WPS)
Compliant Standards IEEE 802.11a, IEEE 802.11d, IEEE 802.11g, IEEE 802.11n
Microsoft Certification Compatible with Windows 7
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
