BenQ 3200 Lumens XGA Resolution DLP Technology Meeting Room Proj
£581.36
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Minimum space constraints
  • Zero eye-blinding lights
  • Zero disruptions
  • High contrast
  • High brightness
  • 2 HDMI ports
  • Enjoy big screen fun from your Android devices with Plug 'N Play
  • Ease of use
  • Built-in speakers
  • SmartEco lamp saving technology
  • Blu-ray Full HD 3D supported
  • Audio pass through
  • Timeless image quality
  • Portability: Portable
  • Stock Status: In Stock
Product codes
Designed to deliver crisp, bright, larger-than-life images from a short projection distance, the BenQ MX631ST is ideal for use in places where space is at a premium such as small conference rooms, training rooms and classrooms. With a powerful 3200 ANSI lumens bright image and an impressive 13000:1 contrast ratio, razor sharp image and rich, accurate colors, the MX631ST will help you present your best.
Product Description BenQ MX631ST - DLP projector - portable - 3D
Device Type DLP projector
3D Capable Yes (3D glasses sold separately)
Built-in Devices Speaker
Brightness 3200 ANSI lumens
Contrast Ratio 13000:1
Resolution XGA (1024 x 768)
Native Aspect Ratio 4:3
Colour Support 1.07 billion colours
Bulb type 196 Watt
Bulb life cycle Up to 4500 hour(s) - normal mode , Up to 6500 hour(s) - economic mode
Video Input RGB, S-Video, composite video, component video (NTSC, SECAM, PAL)
Video Modes 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Speakers Speaker(s) - integrated
Power AC 120/230 V (50/60 Hz)
Power Consumption Operational 305 Watt
Dimensions (WxDxH) 28.73 cm x 23.26 cm x 11.44 cm
Weight 2.6 kg
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
BenQ 3200 Lumens XGA R...
£581.36
