Best Value 3.5" IDE & SATA HDD Enclosure Aluminium U...
Best Value 3.5" IDE & SATA HDD Enclosure Aluminium USB 2.0
£16.32
Delivery:
Standard: 1-3 working days
Product codes
The exciting new USB-HD3.5SI-1A is a stylish, high quality aluminium Disk Enclosure with totally silent operation. The newly designed Aluminium enclosure acts as a built-in heatsink, effectively reducing heat output of the enclosed Hard Disk to enhance reliability and lifespan.
Fully Plug n' Play for leading Operating Systems including MicrosoftTM Windows and MACTM OS X, the USB-HD3.5SI-1A allows your existing 2.5" SATA or IDE Hard Disk to be fitted quickly and with minimal effort. Enjoy fast data transfer speeds courtesy of the USB2.0 interface and immediate data transfer to and from your PC, Notebook or MAC.
  • Stylish and portable aluminium design
  • Ideal for your existing 3.5" IDE or SATA interfaced hard disk drives
  • Re-use your PC, Server or Mac hard disk and keep your data when you upgrade
  • Plug n' Play for popular Operating Systems - no drivers needed
  • External PSU supplied
  • Backup and restore your data at up to 480Mbps
  • Transfer interface USB2.0
  • Transfer rata 480Mbps(MAX)
  • Support HDD 3.5" IDE or SATA interfaced hard disk
  • Work temperature -40? ~ 65?
  • Work humidity 8% ~ 90%
  • Storage humidity 5% ~ 95%
  • Operate system Windows98/SE/ME/2000/XP/VISTA/7/8, Mac OS8.6 or above
Product Description Dynamode USB-HD3.5SI-1 - storage enclosure - ATA - SATA, USB 2.0
Device Type Storage enclosure - external
Bus Type SATA, USB 2.0
Expansion Bays 1 x hot-swap - 3.5"
Hard Drive Form Factor Compatibility 3.5"
Interface ATA
Supported Devices Hard drive
Max Storage Devices Qty 1
Power Source Included AC adapter
System Requirements Linux, Apple MacOS 9.1 or later, Microsoft Windows 98/ME/2000/XP
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Best Value 3.5" IDE &...
£16.32
