BT 5-Port Gigabit Ethernet Switch
Product codes
Documents
Works with any Broadband provider
BT's 5-Port Gigabit Ethernet Switch has been designed to work with any service provider to make sure everyone can make the most of their broadband around their home.
What does BT’s 5-Port Gigabit Ethernet Switch give you?
Connect multiple wired devices to your home router and enjoy a full broadband experience.
Plug & Pay – No install necessary, just instant access to your broadband across all of your devices!
Everyone loves to be online; and why should you settle for anything other than the complete broadband experience? With BT's 5-Port Gigabit Ethernet Switch, you are able to connect multiple wired devices to your home broadband.
Simple to use
The 5-Port Gigabit Ethernet Switch from BT is easy to use. Simply plug into your home router and you are ready to enjoy a complete broadband experience.
Looking for a Superfast Connection
BT's 5-Port Gigabit Ethernet Switch offers speeds up to 10x faster than standard Ethernet so you can realise the full potential of your home broadband.
Make the most of your Broadband
BT's 5-Port Gigabit Ethernet Switch can connect up-to 5 devices to your home router at once. So if you're looking to enjoy a fully connected lifestyle or set-up a home office, BT's 5-Port Gigabit Ethernet Switch will help you make the most of your broadband around your home.
Not the right switch for you?
Too few ports? Try BT's 8-Port Gigabit Ethernet Switch if 5 is just too few.
The BT connectivity range
BT's 5-Port Gigabit Ethernet Switch is just one part of BT's new connectivity range, which has been designed to solve all connectivity issues to ensure everyone makes the most of their broadband around their home. Other products include Broadband Extenders, Dual-Band upgrade kits, Wi-Fi Extenders and switches, ensuring all your major connectivity requirements are covered.
Manufacturer Warranty 3 Years Warranty
Resources
The following resources are available for the BT 5-Port Gigabit Ethernet Switch
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
