Extend your wi-fi throughout your home
These discs only work as an add-on with your other Mini Whole Home Wi-Fi discs
How many discs do you need?
Product Description | BT Mini Whole Home Wi-Fi Add-on disc - radio access point - Wi-Fi 5, Wi-Fi 5 | Device Type | Radio access point | Form Factor | External | Data Link Protocol | IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac | Frequency Band | 2.4 GHz, 5 GHz | Performance | Maximum data rate (2.4 GHz): 300 Mbps , Maximum data rate (5 GHz): 866 Mbps | Power | AC 120/230 V (50/60 Hz) | Dimensions (WxDxH) | 12 cm x 12 cm x 5 cm | Manufacturer Warranty | 3-year warranty |
General | |
Width | 12 cm |
Depth | 12 cm |
Height | 5 cm |
Networking | |
Connectivity Technology | Wireless |
Data Transfer Rate | 866 Mbps |
Wi-Fi Rating | AC1200 |
Status Indicators | WPS, starting, connection status |
Features | Manageable, firmware upgradable, WPA2 encryption, roaming function, Wi-Fi Protected Setup (WPS), reset button, mobile users support, WPA encryption, band steering, AES encryption, quad-stream (4x4), coloured LED status, self-configuring network |
Encryption Algorithm | AES, TKIP, WPA, WPA2, WPS |
Compliant Standards | IEEE 802.3, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11k, IEEE 802.11ac, IEEE 802.11v |
Aerial | |
Antenna | Internal |
Antenna Qty | 4 |
Expansion / Connectivity | |
Interfaces | 1 x 1000Base-T - RJ-45 (WAN) |
Miscellaneous | |
Cables Included | 1 x network cable |
Power | |
Power Device | External power adapter |
Voltage Required | AC 120/230 V (50/60 Hz) |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 85% |
