BT Add-on disc for Mini Whole Home Wi-Fi
FREE DELIVERY
NEW
EXTEND YOUR WI-FI THROUGHOUT YOUR HOME
£59.98
More than 50 in stock
Delivery:
Standard: 1-3 working days
Express: Delivered tomorrow
Express Delivery:
  • 00 h
  • 00 m
  • 00 s
Key features
  • Always connected to a strong Wi-Fi signal in every room
  • Works with all broadband providers
  • These discs only work with other Mini Whole Home Wi-Fi discs
  • Type: Radio access point
  • Connectivity: Wireless
  • Speed: 866Mbps
  • Protocol: IEEE 802.11a, IEEE 802.11ac, IEEE 802.11b, IEEE 802.11g + 1 more
  • Stock Status: In Stock,
    Used stock also available below
Product codes
Extend your wi-fi throughout your home
These discs only work as an add-on with your other Mini Whole Home Wi-Fi discs
How many discs do you need?
  • Smaller homes and flats (1-2 bedrooms) - 2 discs recommended
  • Average homes (3-5 bedrooms) - 3 discs recommended
  • Large homes (6+ bedrooms) - 3 discs + add-on disc reccomended
Product Description BT Mini Whole Home Wi-Fi Add-on disc - radio access point
Device Type Radio access point
Form Factor External
Data Link Protocol IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band 2.4 GHz, 5 GHz
Performance Maximum data rate (2.4 GHz): 300 Mbps , Maximum data rate (5 GHz): 866 Mbps
Power AC 120/230 V (50/60 Hz)
Dimensions (WxDxH) 12 cm x 12 cm x 5 cm
Buy used stock
What is used stock?
Item condition
Accessories
Packaging
Functional
Software
Manuals
product
Customer return - item has been opened but is in excellent condition
Ref: F7C2 043008
£41.56
product
Ref: F7C2 043008
Accessories
Packaging
Functional
Software
Manuals
£41.56
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
BT Add-on disc for Min...
£59.98
