BT Add-on disc for Whole Home Wi-Fi
WORKS WITH ANY BROADBAND SERVICE PROVIDER
£79.99
Select:
More than 50 in stock
Delivery:
Standard: 1-3 working days
Express: Delivered on Tuesday
Express Delivery:
  • 00 h
  • 00 m
  • 00 s
Key features
  • Add this disc to your existing Whole Home Wi-Fi kit to extend coverage even further, ensuring complete Wi-Fi coverage and eliminating deadspots
  • Easy set up in minutes with step by step instructions in the Whole Home Wi-Fi app
  • Intelligent Wi-Fi technology automatically connects you to the fastest and strongest signal as you move from room to room
  • See who is online and pause the Internet with one tap in the app
  • Works with all broadband providers
  • Not compatible with Complete WiFi (Black Discs)
  • Type: Radio access point
  • Connectivity: Wireless
  • Speed: 1733Mbps
  • Protocol: IEEE 802.11a, IEEE 802.11ac, IEEE 802.11b, IEEE 802.11g + 1 more
  • Stock Status: In Stock,
    Used stock also available below
Product codes
Documents
Key Features:
  • Add this disc to your existing Whole Home Wi-Fi kit to extend coverage even further, removing Wi-Fi dead spots. You must add this to an existing Whole Home Wi-Fi set up, it will not work on its own.
  • View your additional disc in the app where you can see who's online and even pause the internet
  • Intelligent Wi-Fi technology automatically connects you to the fastest and strongest signal as you move from room to room (Wi-Fi roaming and band steering)
  • Works with all broadband providers, AC2600 Dual-Band wireless technology
Expand your existing BT Whole Home Wi-Fi network system with this add-on disc. This additional disc will only work when added to BT's Whole Home Wi-Fi solution to further expand your superfast, super-reliable Wi-Fi network. With a mighty AC2500 wireless punch Whole Home Wi-Fi puts what matters most at your fingertips. It talks to all your gadgets to make sure they're always automatically connected to the fastest and strongest signal. And it's bristling with brilliant controls that put you in charge of a supercharged home network. This is Wi-Fi at its finest. With BT Whole Home Wi-Fi you can have your favourite TV, films, music and games in any room you wish. No more dead spots. Even when there's a laptop connected in the kitchen, smartphones upstairs and a tablet in the lounge - they all stay connected, all the time.
Product Description BT Whole Home Wi-Fi Add-on disc - radio access point
Device Type Radio access point
Form Factor External
Data Link Protocol IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band 2.4 GHz, 5 GHz
Dimensions (WxDxH) 16.5 cm x 7.7 cm x 16.5 cm
Weight 415 g
Resources
The following resources are available for the BT Add-on disc for Whole Home Wi-Fi
Buy used stock
What is used stock?
Item condition
Accessories
Packaging
Functional
Software
Manuals
product
Customer return - item has been used and shows signs of use
Ref: CVVT 042699
£53.48
product
Ref: CVVT 042706
£57.70
product
Ref: CVVT 042699
Accessories
Packaging
Functional
Software
Manuals
£53.48
product
Ref: CVVT 042706
Accessories
Packaging
Functional
Software
Manuals
£57.70
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
BT Add-on disc for Who...
£79.99
