BT Add-on Disc for Whole Home Wi-Fi 6 (Single Disc Extension)
FREE DELIVERY
PRICE DROP
LIMITED TIME OFFER
SAVE £20, USUALLY £149.99
£129.99
Select:
  • Add-on
More than 50 in stock
Delivery:
Standard: 1-3 working days
Express: Delivered on Tuesday
Express Delivery:
  • 00
    h
  • 00
    m
  • 00
    s
Key features
  • This disc only works to extend your existing Whole Home Wi-Fi 6 Disc Pack (cannot be used standalone)
  • Works with all broadband providers
  • Expand your existing BT Whole Home Wi-Fi 6 network system with this add-on disc
  • AX6600 Tri-Band wireless technology
  • Wi-Fi roaming and band steering
  • Self-configuring network (star or daisy chain)
  • Type: Radio access point
  • Connectivity: Wireless
  • Protocol: IEEE 802.11n, IEEE 802.11a, IEEE 802.11ac, IEEE 802.11b + 2 more
Product codes
Documents
Whole Home Wi-Fi 6
Our most powerful solution for ultrafast HD streaming and gaming all around your home with any broadband provider
What is wi-fi 6?
Gamers
For PS5 gamers or those with compatible devices, wi-fi 6 means much faster game downloads. Initial connections with friends and opponents online will also improve.
Working from home
The ability to upload and download at the same time means faster speeds and less buffering or congestion, especially in busier homes.
Streaming
Gaming and live TV services benefit as overall speed improves and latency reduces across the network.
Whole Home Wi-Fi 6 Add-on disc
Extend your network even further
Tri-band technology pushes faster, stronger wi-fi to every corner of your home.
The third high-speed channel you get with tri-band allows more devices to connect, and do more at the same time.
Adding an extra disc is perfect for larger homes, those with thick walls or when you need wi-fi in your garage or garden. A maximum of 8 discs can be supported on a network. This disc only works with other Whole Home Wi-Fi 6 discs.
Maximise wi-fi speed and smart connections in every room
Now you can have multiple users streaming TV, films, music and games on any device, in any room, with no dead spots or drop-outs.
  • Placing the discs around your home gives you full coverage and gets rid of wi-fi dead spots.
  • Automatically connects your devices to the fastest, strongest signal as you move around.
  • Even with multiple devices connected you won’t lose speed anywhere in your home.
Whole Home Wi-Fi 6 coverage
Standard router coverage
Benefits of Whole Home Wi-Fi 6
Faster speeds
Wi-fi 6 is much faster and more reliable than wi-fi 5, offering speeds of up to 1200Mbps, that’s 40% more than wi-fi 5.
Improved battery life
Wi-fi 6 in the discs will work together with wi-fi 6 enabled devices to connect only when they need to, thus saving battery life.
Improved network efficiency
Wi-fi 6 allows for simultaneous uplink and downlink which allows discs to transmit to multiple devices at once.
Multi device handling
Wi-fi 6 increases the simultaneous device handling capability by up to 4x more than wi-fi 5.
Improved coverage
Wi-fi 6 offers increased bandwidth. This means that ultrafast speeds are pushed even further as uploading doesn’t slow traffic or clog capacity.
Enhanced security
Wi-fi 6 has WPA3 technology built in. Enhanced encryption means your data is better protected.
Product Description BT Mini Whole Home Wi-Fi 6 - Add-on - radio access point - Wi-Fi 6
Device Type Radio access point
Form Factor External
Data Link Protocol IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, IEEE 802.11ax (Wi-Fi 6)
Frequency Band 2.4 GHz (1 band) / 5 GHz (2 bands)
Performance Maximum data rate (2.4 GHz): 574 Mbps , Maximum data rate (5 GHz): 4.8 Gbps
Power AC 230 V (50 Hz)
Dimensions (WxDxH) 18.2 cm x 7.1 cm x 18.2 cm
Weight 468 g
Resources
The following resources are available for the BT Add-on Disc for Whole Home Wi-Fi 6 (Single Disc Extension)
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£129.99
