BT Advanced Phone - One Handset
FREE DELIVERY
100% CALL BLOCKING AND ANSWER MACHINE
None in stock
Key features
  • Block up to 1000 numbers
  • Excellent sound quality
  • Easy set up
  • Handsfree speaker
  • Long range reception
  • 22 hours of talking or 240 hours standby time
  • See and hear if you have a second call waiting
  • Easy to read screen shows when you have messages
  • Dedicated Call Block Button
  • Save up to 200 contacts
  • Redial any of the last 30 calls you made
  • Record up to 30 minutes of messages
  • 1.8 inch monochrome black and white screen
Product codes
Documents
Advanced Phone with 100% call blocking and answer machine
  • trueCall virtual assistant filters and announces all unknown calls
  • Handsfree speaker
  • Automatically share contacts between handsets
Call blocking
  • Incorportates award-winning trueCall call blocking technology
  • Block 100% nuisance calls*
  • Save contacts get straight through
  • Virtual assistant filters and announces all unknown calls
  • Block 1000 numbers
  • Dedicated call block button
  • Do Not Disturb mode
Key benefits
  • Easy set up
  • Handsfree speaker
  • Adjust the volume if the caller is too quiet (or too loud)
  • See who's calling before you pick up
  • 1.8 inch monochrome screen
  • Auto-share contacts between handsets
*You must subscribe to a Caller Display service from your network provider for the block nuisance calls feature to work. Charges may apply.
Product Description BT Advanced Phone - cordless phone - answering system with caller ID
Product Type Cordless phone answering system with caller ID
Total Number of Wireless Handsets 1
Cordless Phone Standard DECT\GAP
Speakerphone Yes
Call Services Call Waiting, Call Transfer, Call Block
Display LCD display - monochrome - Yes
Resources
The following resources are available for the BT Advanced Phone - One Handset
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
BT Advanced Phone - On...
