with 100% call blocking and answer machine
Only talk to the people you want to. Block 100% of nuisance calls with the trueCall™ virtual assistant.
Featuring
1 You need to have a Caller Display service from your network provider for the block nuisance calls feature to work. Charges may apply.
Call blocking puts you back in control by allowing you to choose the calls you want to take and those you want to block. This means any caller not on your contact list or already blocked will have to announce their name before getting through so you can choose whether to accept or reject the call. You can also choose to block certain types of call like international or withheld numbers.
You can save up to 200 contacts and these are automatically copied to all handsets if you buy a multi pack or register extra handsets. Outgoing call control lets you set a PIN to protect calls to mobile, international and premium rate numbers to prevent any surprises on your bill.
The Do Not Disturb feature is great for when you need some quiet time, just turn on and your calls will still get through and show on the screen but your handset won’t ring and the handset display won’t light up.
Save up to 30 minutes of messages. You can playback your messages privately through the handset or using the handsfree speaker. And don’t miss important messages when away from home with remote access to your messages.
Product Description | BT Advanced Phone Trio - cordless phone - answering system with caller ID + 2 additional handsets | Product Type | Cordless phone answering system with caller ID + 2 additional handsets | Total Number of Wireless Handsets | 3 | Cordless Phone Standard | DECT\GAP | Speakerphone | Yes | Call Services | Call Waiting, Call Transfer, Call Block | Display | LCD display - monochrome - Yes |
General | |
Product Type | Cordless phone answering system |
Additional Handsets Qty | 2 |
Phone Features | |
Caller ID Type | Caller ID |
Max Handsets Supported | 6 |
Max Handset Operating Distance | 50 m |
Max Handset Operating Distance (Outdoor) | 300 m |
Dialer Location | Handset |
Conference Call Capability | Yes |
Volume Control | Yes |
Ring Tones | 15 |
Polyphonic Ringer | Yes |
Handset Locator | Yes |
Indicators | Visual ringer light |
Additional Functions | Call timer, built-in clock, Alarm, Intercom, keyboard lock |
Phone Memory | |
Phone Directory Capacity | 200 names & numbers |
Caller ID Memory | 30 names & numbers |
Answering System | |
Recording Capacity | 30 min |
Display | |
Type | LCD display - monochrome |
Display Location | Handset |
Diagonal Size | 1.8" |
Backlit | Yes |
Miscellaneous | |
Placing / Mounting | Table-top |
Battery | |
Battery | AAA type |
Capacity | 750 mAh |
Technology | Rechargeable - Nickel Metal Hydride |
Talk Time | Up to 1320 min |
Standby Time | Up to 240 h |
Dimensions & Weight (Base) | |
Width | 8.2 cm |
Depth | 4.3 cm |
Height | 14.2 cm |
Weight | 121.6 g |
Dimensions & Weight (Handset) | |
Width | 5.1 cm |
Depth | 3.5 cm |
Height | 17.6 cm |
Weight | 123.2 g |
The following resources are available for the BT Advanced Phone - Three Handsets
