BT Advanced Phone Z - Quad Pack
FREE DELIVERY
£79.99
Select:
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Block up to 1000 numbers
  • Excellent sound quality
  • Easy set up
  • Handsfree speaker
  • Long range reception
  • 22 hours of talking or 240 hours standby time
  • See and hear if you have a second call waiting
  • Easy to read screen shows when you have messages
  • Dedicated Call Block Button
  • Save up to 200 contacts
  • Redial any of the last 30 calls you made
  • Record up to 30 minutes of messages
  • 1.8 inch monochrome black and white screen
  • Stock Status: Clearance
Product codes
Advanced Phone Z with 100% nuisance call blocking and answer machine
The Advanced Phone Z, powered by trueCall’s award winning technology. Have complete control over which calls you want to take and those you want to block.
Nuisance Call blocking features
Avoid unwanted calls. Block up to 1000 specific numbers or use Do Not Disturb to silence your calls.
Easy set up and great sound quality
Get the most out of your phone straight away with our easy to use menu. And enjoy high quality clear calls.
  • Easy set up
  • Handsfree speaker
  • Long range reception, up to 300m outdoors, 50m indoors
  • 22 hours of talking OR 240 hours standby time
  • 1.8 inch monochrone black and white screen
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
BT Advanced Phone Z -...
£79.99
