BT Advanced Phone Z - Trio Pack
FREE DELIVERY
Select:
  • Trio
Key features
  • Excellent sound quality
  • Easy setup
  • Record up to 30 minutes of messages
  • Save up to 200 contacts
  • Handsfree speaker
  • Redial any of the last 30 calls you made
  • Adjust the volume if the caller is too quiet (or too loud)
  • See who's calling before you pick up
  • 1.8 inch monochrome screen
  • Auto-share contacts between handsets
Product codes
Advanced Phone Z with 100% nuisance call blocking and answer machine
The Advanced Phone Z, powered by trueCall’s award winning technology. Have complete control over which calls you want to take and those you want to block.
Nuisance Call blocking features
Avoid unwanted calls. Block up to 1000 specific numbers or use Do Not Disturb to silence your calls.
Easy set up and great sound quality
Get the most out of your phone straight away with our easy to use menu. And enjoy high quality clear calls.
  • Block up to 1000 numbers
  • Easy set up
  • Handsfree speaker
  • Long range reception, up to 300m outdoors, 50m indoors
  • 22 hours of talking OR 240 hours standby time
  • See and hear if you have a second call waiting
  • Easy to read screen shows when you have messages
  • Dedicated Call Block Button
  • 1.8 inch monochrone black and white screen
Product Description BT Advanced Phone Z Trio - cordless phone - answering system with caller ID + 2 additional handsets
Product Type Cordless phone answering system with caller ID + 2 additional handsets
Total Number of Wireless Handsets 3
Cordless Phone Standard DECT\GAP
Speakerphone Yes
Call Services Call Waiting, Call Block
Display LCD display - monochrome - Yes
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
