BT Audio Baby Monitor 450 Lightshow
PRICE DROP
LIMITED TIME OFFER
SAVE £10! USUALLY £49.99
£39.99
Delivery:
Standard: 1-3 working days
Express: Delivered on Wednesday
Express Delivery:
  • 00 h
  • 00 m
  • 00 s
Key features
  • The Star and Moon Lightshow projects gentle colored shapes onto your baby's ceiling
  • Use the lullabies to help your baby drift off to sleep
  • The adjustable night light is built in to help you find your way in the dark
  • The two way talk back feature reassures your baby that you are always there for them
  • Stock Status: In Stock
Product codes
Documents
The Audio Baby Monitor 450 helps your baby drift off to sleep with a star and moon lightshow. Choose from up to 18 different lullabies and never miss a sound with crystal clear interference free audio, giving you peace of mind. Sound level LED's alert you visually to any sounds coming from your baby's room and when you just want to reassure your baby you're always there, the two way communication talk back feature keeps your baby and you connected.
Key features
  • Need something to help your baby drift off to sleep? The Star and Moon Lightshow projects gentle coloured shapes onto your baby's ceiling to calm your baby. Use the lullabies to help them drift off to sleep.
  • Don't want to wake up your bundle of joy? We know it can be hard work to get your little one fast asleep. Which is why the adjustable night light is built in to help you find your way in the dark.
  • Want constant connection? The two way talk back feature reassures your baby that you are always there for them, or is an easy way to talk to your partner when one of you is in the nursery.
Why BT?
BT is a trusted brand for keeping you close to the people that matter most. Our previous range of baby monitors won multiple awards and the new range of monitors builds upon the previous strengths to make your life easier, by keeping you close to your little ones.
What's in the box?
Audio baby monitor 450 comes with, a parent unit for you, a monitor for the baby's room, two mains power adaptors, two rechargeable batteries and a user guide to walk you through the set up process.
Comparison Chart
 ABM 400ABM 450VBM 2000VBM 3000VBM 5000VBM 6000
Range300m300m250m250m250m250m
Screen size 1.8"2.0"2.8"2.8"5.0"
No. of lullabies 18 555
Star and moon lightshow Yes
Two way talk back Yes YesYesYes
Zoom in on video  YesYesYesYes
Adjust camera angle remotely    YesYes
Temperature display Yes YesYesYes
Product Description BT Audio 450 Lightshow baby monitoring system
Product Type Baby monitoring system
Components Baby unit, parent unit
Vibrating Alert Yes
Display LCD display monochrome - backlit
Battery Rechargeable
Colour White, purple
Resources
The following resources are available for the BT Audio Baby Monitor 450 Lightshow
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
BT Audio Baby Monitor...
£39.99
