BT Baby Monitor 250
BT Baby Monitor 250
SAVE £30! WAS £69.99
Product codes
Documents
Award-winning Baby Monitor 250
BT Baby Monitor 250
A great baby monitor can make a real difference. It'll help make life easier for you, and give you complete reassurance by keeping you close to your baby, even when you're away.
One of the best buys you can make for you and your baby is a baby monitor. The best monitors have grown up and adopted all sorts of new technology, so you'll be amazed by what they can do.
  • Digital DECT technology
  • Hi-definition sound
  • Eight lullabies with superb sound
  • Blue backlit LCD on parent unit
  • Temperature changing nightlight
  • Parent talk back
  • Vibrate alerts
  • Torch
  • Travel bag
  • Crying alert
  • Belt Clip
Colour White/Purple
Sound Sensitvity LEDs Yes
Torch Yes
Wipeable keys on both units Yes
Mute Low/Mute All Yes
Power On/Off Yes
Nightlight Yes
Crying Alert Yes
Paging Yes
Low battery alert Yes
Battery Type (parent) NiMH
Belt Clip Yes
Volume Control Yes
Battery Size (parent) AA
Battery Capacity (parent) 1300mAh
Wall Mount No
Clock No
Vibrating Alert Yes
PSU item code (parent) 05771
Timer Yes
Temperature Alert Yes
Range Up to 300m/50m
Out of range alert Yes
Paging Yes
Talk back Yes
Baby Unit PSU item code 05771
Baby Unit Weight 146g
Parent Unit Weight 133g
Charger Weight 41g
PSU Weight 178g
Baby Unit Dimensions 5.7 x 11 x 150.6 cm
Parent Unit Dimensions 4.8 x 6.7 x 12 cm
Charger Dimensions 3.8 x 8.6 x 6.9 cm
Country of Manufacture China
Resources
The following resources are available for the BT Baby Monitor 250
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
BT Baby Monitor 250
