BT Broadband Extender 600 Kit
FREE DELIVERY
Product codes
Documents
Works with any Broadband provider
BT’s Broadband Extender 600 Kit has been designed to work with any service provider to make sure everyone can make the most of their Broadband around their home.
What does BT’s Broadband Extender 600 Kit give you?
Connect any wired device to your home broadband anywhere in your home with our powerline technology and enjoy the full broadband experience.
Plug & Play - No install necessary, just instant access to your broadband anywhere in your home!
Everyone loves to be online; and why should you settle for anything other than the complete broadband experience? With BT’s Broadband Extender 600 Kit, you are able to connect any wired device wherever and whenever you like.
With up to 500 Mbps for smooth HD/3D streaming, online gaming or faster downloads, BT's Broadband Extender 600 Kit supports all your online needs.
Simple to use
BT's Broadband Extender 600 Kit is easy to use. Simply plug into your wall socket and you are ready to enjoy a complete broadband experience.
Make the most of your Broadband
BT's Broadband Extender 600 Kit offers a solution to a number of your broadband problems. Be it connecting a Smart TV in a different room to your router, using an old laptop without Wi-Fi capability or getting the best online gaming experience possible, BT's Broadband Extender 600 Kit can be used to help make the most of your Broadband at home.
Compatible with other technologies
BT's Broadband Extender 600 Kit BT works seamlessly with all other BT Broadband Extender products to create your new home network. It is also completely compatible with other AV HomePlug powerlines so you can integrate it with an existing Powerline network. The Broadband Extender 600 Kit utilises HomePlug AV500 Powerline technology and can be fully integrated with an existing AV500 network in your home.
Better for the environment
Eco credentials come as standard with built-in power saving and fully recyclable packaging.
Resources
The following resources are available for the BT Broadband Extender 600 Kit
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
