Our latest hub is designed to make the most of superfast broadband speeds and has innovative features making it more efficient, reliable, secure and easier to use, as well as environmentally friendly.
It also gives you the UK's most reliable wireless connection. Our Smart Wireless™ technology means you get the strongest signal possible from the BT Business Hub 3 to your devices compared with other major broadband providers.
Wireless-N Technology - A smart antenna and signal processing that gives up to five-times the performance and up to twice the range, compared to our previous BT Business Hub.
Smart Wireless™ - Chooses your clearest signal at any time to give you the UK's most reliable connection from hub to device compared to all other major broadband providers.
Wi-Fi Protected Setup (WPS) - New wireless networks are automatically configured, so new devices can be added without the need for wi-fi expertise.
Gigabit Ethernet - The capability to keep up with superfast broadband. Multiple users will experience faster performance.
Energy Efficiency - Uses 30% less energy (half the power of an energy-efficient lightbulb), and goes into power save mode as soon as there is no traffic.
Fibre Support | Yes | Modem Type | ADSL2+ | Access Methods supported | IP Stream, ADSL, FTTC & FTTP | 802.11b support | Yes | 802.11g support | Yes | 802.11n support | Yes | Draft 802.11n 5GHz support | No | Stated Speed | 3 x 10/100 Mbit/s Ethernet sockets (RJ45), 1 x 10/100/1000 Mbit/s Ethernet socket (RJ45) | 128-bit WEP | Yes | WPA | PSK | Firewall | Yes | MAC Address Filtering | Yes | DMZ | Yes | WPS | Yes | Size | 107x185x62mm | Antennas | 2 | Internal/External antennas | Internal | Number of WAN ports | 2 (1 x DSL and x Ethernet) | Ethernet ports | 4 | Ethernet connection speed | 10/100/1000Mbit/s | Other ports | USB |
