BT Digital Voice Adapter
ONLY WORKS WITH BT DIGITAL VOICE SERVICE
£14.98
More than 50 In Stock
Delivery:
Standard: 1-3 working days
Express: Delivered tomorrow
Express Delivery:
  • 00
    h
  • 00
    m
  • 00
    s
Key features
  • This Adapter allows you the freedom to keep using your existing home phones when your service moves to Digital Voice
  • Works with BT Hubs
Product codes
This Adapter allows you the freedom to keep using your existing home phones when your service moves to Digital Voice. If your current home phone is a DECT Cordless phone, with or without additional handsets, you will only need 1 Adapter.
If you only use Corded phones in your home, you will need an Adapter per phone. (You can have up to 5 Digital Voice products registered to the Smart Hub 2, this includes the Digital Voice Adapter)
You require an adapter if:
  • You want your DECT phone in a different location to your Smart Hub. You'll only need 1 Adapter
  • You use Corded phones around your house. You'll need an Adapter per Corded phone
You do not need an adapter if:
  • It's convenient for you to plug either your Corded or Cordless phone directly into the green port at the back of your Smart Hub 2.
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£14.98
