BT Dual-band AC Wireless USB Dongle
Product codes
The BT dual-band ac wireless USB dongle allows you to take advantage of the brand new AC wireless technology that comes with the BT Home Hub 5.
The new smart ac wireless on the Hub 5 supports full Infinity 2 speeds wirelessly. This offers the best out of BT Infinity fibre optic broadband whatever you use it for. This makes Hub 5 one of the fastest in the UK!
Some of the latest devices like the Samsung Galaxy S4 or the latest Apple MacBook Air come with AC built in. However, this brand new dongle provides Dual-Band ac wireless for devices that don't support this technology and allows you to enjoy the benefits of ac wireless on your existing devices.
It is compatible with Windows Vista, 7 and 8.
Why not add up to 3 dongles to your order and get the most from BT Infinity from most or all of your laptops!
This device is a 802.11 a/b/g/n/ac Dual Band Wireless LAN USB Dongle for use with desktop PCs, laptops and other compatible devices to allow wireless connection to 2.4GHz and 5GHz Access Points and adhoc connection to other clients.
*Highly integrated single chip CMOS solution, minimizing power consumption and cost while maximizing reliability *Fully supports 5GHz Dynamic Frequency Selection (DFS) and Transmit Power Control (TPC) from 802.11h, WMM (QoS) from 802.11e.
Technical Specifications *Standard - 2.4GHz 802.11b/g/n *5GHz 802.11a/n/ac Modes 2.4GHz: *20MHz: 802.11b/g *40MHz: 802.11n 5GHz: *20MHz: 802.11a/n/ac *40MHz: 802.11n/ac *80MHz: 802.11ac *Interoperability: The device shall interoperate with all major 802.11ac AP chipsets. **Antenna type: 2x2 MIMO internal antenna
Software *OS Support Windows Vista, 7, 8. This shall include both 32bit and 64bit versions and all service packs unless otherwise stated. *Mac OSX is not supported *Certified for Windows (WHQL) *Windows Vista, 7, 8 Both 32 & 64bit versions for each OS. **Installation Experience Windows certified drivers shall be distributed via Windows update.
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
