BT Elements 1K Twin
BT Elements 1K Twin
£129.99
Delivery:
Standard: 1-3 working days
Express: Delivered tomorrow
Express Delivery:
  • 00 h
  • 00 m
  • 00 s
  • Stock Status: In Stock
Product codes
Documents
Bundle deals (1)
ANTIBACTERIAL WIPES
ANTIBACTERIAL WIPES
= £133.48
Save £1.50
BT Elements 1km range IP67 Rated Cordless Phone with Answer Machine and Nuisance Call Blocker
The BT Elements 1 km long range IP67 rated Cordless Phone with Answer Machine with up to 30 mins recording time and Nuisance Call Blocker. More rugged, more robust and far more aesthetically pleasing than its predecessor this BT Elements is ideal for the workshop, the warehouse, the outdoors or even just at home with the kids.
This robust BT Elements is IP67 rated meaning this ruggedised handset is protected from dust and water immersion (depth between 15 cm and 1 m for up to 30 mins).
This phone also has a long cordless outdoor range of up to 1 km and up to 50 m indoors.
Nuisance Call Blocking Technology installed
Fed up with unwanted calls interrupting you at home or at work? This phone's Nuisance Call Blocker puts you back in control by enabling you to choose the calls you want to take and those you want to block.
With up to 13 hrs talktime, up to 160 hrs standby time, handy belt clip and handsfree feature, this phone will let you move around freely when life gets busy. The integrated answer machine also makes sure you never miss an important message should you miss or not be able to take a call. This phone also supports SMS text messaging and features a clock, calendar and alarm.
Other useful features
  • 200 name and number directory
  • a handy 6 line mono display which is backlit and has contrast control
  • 50 number calls list
  • 30 number redial list
  • call waiting indicator
  • 10 polyphonic and 5 standard ringtones
  • a VIP indicator
  • 9 quick dial memories
  • a keypad lock and secrecy function
Resources
The following resources are available for the BT Elements 1K Twin
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
BT Elements 1K Twin
£129.99
