with easy call blocking and answer machine
Stay in control of who you speak to by easily blocking nuisance calls from specific numbers and call types.
Featuring
1 You need to have a Caller Display service from your network provider for the block nuisance calls feature to work. Charges may apply.
Call Blocking puts you back in control by allowing you to choose the calls you want to take and those you want to block. You can block specific call types, like international and withheld numbers and use the one touch call blocking button to block an incoming call or if you’ve answered a call, press to stop the number calling again. You can also store up to 100 specific numbers you don’t want calling you.
An easy to set up phone with excellent sound quality. You can save up to 100 contacts to your phonebook and even set some contacts as VIP callers to ensure they will always get through when Call Blocking is on and set to Allow VIP.
Save up to 30 minutes of messages. You can playback your messages privately through the handset or using the handsfree speaker. And don’t miss important messages when away from home with remote access to your messages.
Handsfree lets you talk to your caller without holding the handset, so you’re free to get on with other things, make notes or let other people in the room listen to the conversation over the loudspeaker.
Product Description | BT Essential Phone Trio - cordless phone - answering system with caller ID + 2 additional handsets | Product Type | Cordless phone answering system with caller ID + 2 additional handsets | Total Number of Wireless Handsets | 3 | Cordless Phone Standard | DECT\GAP | Speakerphone | Yes | Call Services | Call Waiting, Call Transfer, Call Block | Display | LCD display - monochrome - Yes |
General | |
Product Type | Cordless phone answering system |
Additional Handsets Qty | 2 |
Phone Features | |
Caller ID Type | Caller ID |
Max Handsets Supported | 4 |
Max Handset Operating Distance | 50 m |
Max Handset Operating Distance (Outdoor) | 300 m |
Dialer Location | Handset |
Conference Call Capability | Yes |
Volume Control | Yes |
Ring Tones | 10 |
Handset Locator | Yes |
Indicators | Visual ringer light |
Additional Functions | Call timer, built-in clock, Alarm, Intercom, keyboard lock |
Phone Memory | |
Phone Directory Capacity | 100 names & numbers |
Caller ID Memory | 10 names & numbers |
Answering System | |
Recording Capacity | 30 min |
Display | |
Type | LCD display - monochrome |
Display Location | Handset |
Diagonal Size | 1.8" |
Backlit | Yes |
Miscellaneous | |
Placing / Mounting | Table-top |
Battery | |
Battery | AAA type |
Capacity | 550 mAh |
Technology | Rechargeable - Nickel Metal Hydride |
Talk Time | Up to 720 min |
Standby Time | Up to 120 h |
Dimensions & Weight (Base) | |
Width | 9.2 cm |
Depth | 4.5 cm |
Height | 12.9 cm |
Weight | 128.8 g |
Dimensions & Weight (Handset) | |
Width | 5.1 cm |
Depth | 3.5 cm |
Height | 17.8 cm |
Weight | 123.2 g |
The following resources are available for the BT Essential Phone - Three Handsets
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
