BT Everyday Phone with Answer Machine - One Handset
£29.98
Select:
10 in stock
Delivery:
Standard: 1-3 working days
  • Type: Cordless phone
  • Handsets Included: 1
  • Answer Machine: Yes
  • Nuisance Call Blocker: Yes
  • Big Button: No
Product codes
Documents
Everyday Phone with call blocking and answer machine
Nuisance Call Blocking
  • Only talk to the people you want to by blocking up to 20 numbers.
  • For peace and quiet, switch on Do Not Disturb so that your phone won't ring or light up.
Easy to Use
  • Our BT phones have excellent sound quality with volume adjustment to suit your needs.
  • See whose calling before answering on the 1.5" amber display.
Freedom to move in your house
  • Save up to 50 contact. All these contacts are automatically copied to all of your handsets
  • Adjust the volume if the caller is too loud or too quiet
*You must subscribe to a Caller Display service from your network provider for the block nuisance calls feature to work. Charges may apply.
Resources
The following resources are available for the BT Everyday Phone with Answer Machine - One Handset
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
BT Everyday Phone with...
£29.98
