BT Everyday Phone without Answer Machine - Three Handsets
£49.99
Select:
10 in stock
Delivery:
Standard: 1-3 working days
Express: Delivered on Thursday
Express Delivery:
  • 00 h
  • 00 m
  • 00 s
Key features
  • Block up to 20 numbers
  • Excellent sound quality
  • Easy set up
  • See and hear if you have a second call waiting
  • See who's calling before you pick up
  • Easy to read screen shows when you have messages
  • Do Not Disturb mode
  • Save up to 50 contacts
  • Redial any of the last 20 calls you made
  • 1.6 inch amber screen
  • Type: Cordless phone
  • Handsets Included: 3
  • Answer Machine: No
  • Nuisance Call Blocker: Yes
  • Mounting: Table-top
Product codes
Documents
The Everyday Phone Nuisance Call Blocker, gives you back control over which calls you want to take and which you want to block. The Everyday Phone can block 20 individual numbers, meaning that you really can avoid speaking to the people you don't want to. For those times when you just want some peace and quiet, switch on Block All so that your phone won't ring. If you want key friends and family to still get through, they can do, by tagging them as VIP's in your address book. Easy set up and long range reception, up to 300m outdoors, 50m indoors.
Nuisance Call Blocking
Only talk to the people you want to by blocking up to 20 numbers*.
For peace and quiet, switch on Do Not Disturb so that your phone won't ring or light up.
Easy to Use
Our BT phones have excellent sound quality with volume adjustment to suit your needs.
See whose calling before answering on the 1.5" amber display.
Freedom to move in your house
Save up to 50 contact. All these contacts are automatically copied to all of your handsets
Adjust the volume if the caller is too loud or too quiet
Box Contains
1 x Base Unit including charger
2 x Additional charger
3 x Handsets
Rechargeable batteries
2 x Mains power adaptor
1 x Telephone line cord
User Guide
Product Description BT Everyday Phone Trio - cordless phone with caller ID + 2 additional handsets
Product Type Cordless phone with caller ID + 2 additional handsets
Total Number of Wireless Handsets 3
Cordless Phone Standard DECT\GAP
Speakerphone Yes
Call Services Call Waiting, Call Transfer
Display LCD display - monochrome - Yes
Resources
The following resources are available for the BT Everyday Phone without Answer Machine - Three Handsets
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
BT Everyday Phone with...
£49.99
