Did you know the telephone extension wiring in your house can pick up all sorts of electrical noise and interference from TV's, lights and other everyday electrical equipment? This interference can affect your broadband signal resulting in a slower broadband speed.
Help is at hand! BT has developed the I-Plate, a unique filter that helps stop any interference affecting the broadband signal. As long as you have a suitable BT Master socket, (see below) and extension wiring (see below) the I-Plate can help. It's quick and easy to fit with a screwdriver and you don't need to disconnect any wires.
In previous tests the I-Plate has been shown to boost line speeds - typically by 1.5Mbps. The actual change will vary from house to house. Although speed improvements are likely, they can't be guaranteed. The improvements in speed will take up to 2 weeks to come through so that line stability is not affected. Even if it doesn't improve the speed the I-Plate can help stabilise your broadband line making it more reliable.
Extension wiring is the telephone wiring, usually a small white cable, which often runs along your skirting boards or outside your house. It connects the main socket to any extension sockets you have. It doesn't matter if you use the sockets or not, as long as the wiring is there the I-Plate may help.
For pictures of these sockets, click on the link at the top of this page "Will the I-Plate work with your phone socket?"
iplate
The following resources are available for the BT Iplate / BT Broadband Accelerator
