BT Mini Connector Kit
WORKS WITH ALL BROADBAND PROVIDERS
£89.98
35 in stock
Delivery:
Standard: 1-3 working days
Express: Delivered on Monday
Express Delivery:
  • 00 h
  • 00 m
  • 00 s
  • Stock Status: In Stock
Product codes
Documents
The BT Mini Connectors allow you to connect your BT TV box to your BT Hub.
  • They work with all our Hubs, without having to run an Ethernet cable all the way around the home. They do this by sending your broadband signal through the electrical wiring in your home.
  • They also have a power socket on the front, so you don't lose a plug socket on your wall. We recommend you use this socket to plug in any plug boards or your BT TV box itself.
  • This product supports On Demand, Catch Up and Extra TV Channels through BT TV.
  • The BT Mini Connectors work with speeds of up to 1GB and can even be used with our Ultra HD. This makes it easy for you to self install BT TV Ultra HD without an engineer visit.
Resources
The following resources are available for the BT Mini Connector Kit
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
£89.98
