BT Mini Whole Home Wi-Fi - Two Discs
FREE DELIVERY
NEW
EXTEND YOUR WI-FI THROUGHOUT YOUR HOME
£74.98
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Always connected to a strong Wi-Fi signal in every room
  • Works with all broadband providers
  • These discs only work with other Mini Whole Home Wi-Fi discs
  • Type: Whole Home Wi-Fi
  • Connectivity: Wireless
  • Speed: 866Mbps
  • Protocol: IEEE 802.11a, IEEE 802.11ac, IEEE 802.11b, IEEE 802.11g + 1 more
  • Stock Status: In Stock,
    Used stock also available below
Product codes
Extend your wi-fi throughout your home
Perfect for families or households that want all their devices connected to a strong, fast wi-fi signal in every room.
Intelligent wi-fi that covers the whole home
  • Placing the discs around your home gives you full control and gets rid of wi-fi dead spots
  • Automatically connects your devices to the fastest, strongest signal as you move around
  • Even with multiple devices connected you won't lose speed anywhere in your home
Now you can have TV, films, music and games on any device, in any room, with no dead spots or drop-outs.
The super smart app locates the best place for your discs, and gives you ultimate control over your broadband
  • Use the app to view your network, see who's online and even pause the internet
  • Dual-band AC1200 wi-fi gives you fast wi-fi as you move from room to room
  • Two discs remove dead spots, creating a complete wi-fi network, so every device stays connected everywhere in your home
How many discs do you need?
  • Smaller homes and flats (1-2 bedrooms) - 2 discs recommended
  • Average homes (3-5 bedrooms) - 3 discs recommended
  • Large homes (6+ bedrooms) - 3 discs + add-on disc reccomended
Product Description BT Mini Whole Home Wi-Fi - radio access point
Device Type Radio access point
Packaged Quantity 2 (specifications are for single item)
Form Factor External
Data Link Protocol IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band 2.4 GHz, 5 GHz
Performance Maximum data rate (2.4 GHz): 300 Mbps , Maximum data rate (5 GHz): 866 Mbps
Dimensions (WxDxH) 12 cm x 12 cm x 5 cm
Buy used stock
What is used stock?
Item condition
Accessories
Packaging
Functional
Software
Manuals
product
Customer return - item has been used and shows signs of use
Ref: F7BZ 042190
£56.19
product
Ref: F7BZ 042190
Accessories
Packaging
Functional
Software
Manuals
£56.19
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
BT Mini Whole Home Wi-...
£74.98
