Extend your wi-fi throughout your home
Perfect for families or households that want all their devices connected to a strong, fast wi-fi signal in every room.
Intelligent wi-fi that covers the whole home
Now you can have TV, films, music and games on any device, in any room, with no dead spots or drop-outs.
The super smart app locates the best place for your discs, and gives you ultimate control over your broadband
These discs only work with other Mini Whole Home Wi-Fi discs
Product Description | BT Mini Whole Home Wi-Fi - radio access point | Device Type | Radio access point | Packaged Quantity | 5 (specifications are for single item) | Form Factor | External | Data Link Protocol | IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac | Frequency Band | 2.4 GHz, 5 GHz | Performance | Maximum data rate (2.4 GHz): 300 Mbps , Maximum data rate (5 GHz): 866 Mbps | Power | AC 120/230 V (50/60 Hz) | Dimensions (WxDxH) | 12 cm x 12 cm x 5 cm | Manufacturer Warranty | 3-year warranty |
Customer return - item has been opened but is in excellent condition
Ref: FG7X 041318 |
Accessories | |
Packaging | |
Functional | |
Software | |
Manuals | |
