Push faster, stronger wi-fi to every corner of your home
Perfect for bigger families or households with multiple users streaming content or gaming at the same time. The best solution for maintaining faster, stronger wi-fi in every room.
The latest tri-band technology pushes faster, stronger wi-fi to every corner of your home
The super smart app locates the best place for your discs, and gives you ultimate control over your broadband
Intelligent wi-fi that covers the whole home
Now you can have TV, films, music and games on any device, in any room, with no dead spots or drop-outs.
Product Description | BT Premium Whole Home Wi-Fi - radio access point | Device Type | Radio access point | Packaged Quantity | 2 (specifications are for single item) | Form Factor | External | Data Link Protocol | IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac | Frequency Band | 2.4 GHz, 5 GHz | Manufacturer Warranty | 3-year warranty |
General | |
Networking | |
Connectivity Technology | Wireless |
Status Indicators | WPS, starting, connection status |
Features | Manageable, firmware upgradable, WPA2 encryption, roaming function, Wi-Fi Protected Setup (WPS), reset button, mobile users support, WPA encryption, band steering, AES encryption, quad-stream (4x4), coloured LED status, self-configuring network |
Encryption Algorithm | AES, TKIP, WPA, WPA2, WPS |
Compliant Standards | IEEE 802.3, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11k, IEEE 802.11ac, IEEE 802.11v |
Aerial | |
Antenna | Internal |
Antenna Qty | 4 |
Expansion / Connectivity | |
Interfaces | 1 x 1000Base-T - RJ-45 (WAN) |
Miscellaneous | |
Cables Included | 1 x network cable |
Power | |
Power Device | External power adapter |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 85% |
