Refurbished stock with 1 year warranty. Fully tested grade A condition, external packaging may have some minor cosmetic damage.
Push faster, stronger wi-fi to every corner of your home. Using the latest AX6600 Tri-band Wi-Fi technology to create a complete Wi-Fi network.
Product Description | BT Mini Whole Home Wi-Fi 6 - Add-on - radio access point - Wi-Fi 6 | Device Type | Radio access point | Form Factor | External | Data Link Protocol | IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, IEEE 802.11ax (Wi-Fi 6) | Frequency Band | 2.4 GHz (1 band) / 5 GHz (2 bands) | Performance | Maximum data rate (2.4 GHz): 574 Mbps , Maximum data rate (5 GHz): 4.8 Gbps | Power | AC 230 V (50 Hz) | Dimensions (WxDxH) | 18.2 cm x 7.1 cm x 18.2 cm | Weight | 468 g |
General | |
Width | 18.2 cm |
Depth | 7.1 cm |
Height | 18.2 cm |
Weight | 468 g |
Networking | |
Connectivity Technology | Wireless |
Features | Roaming function, Wi-Fi Protected Setup (WPS), reset button, band steering, Backhaul Technology, 2x2 MIMO technology, 4x4 MIMO technology |
Encryption Algorithm | AES, WPA, WPA2, WPA3 |
Compliant Standards | IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11k, IEEE 802.11ac, IEEE 802.11v, IEEE 802.11ax |
Aerial | |
Antenna | Internal |
Expansion / Connectivity | |
Interfaces | 2 x 1000Base-T - RJ-45 |
Miscellaneous | |
Cables Included | 1 x network cable |
Power | |
Power Device | External power adapter |
Voltage Required | AC 230 V (50 Hz) |
Power Consumption Operational | 11.4 Watt |
Dimensions & Weight (Shipping) | |
Shipping Width | 8.15 cm |
Shipping Depth | 20.5 cm |
Shipping Height | 26 cm |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 45 °C |
Humidity Range Operating | 10 - 90% |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
