BT Refurbished Whole Home Wi-Fi Twin
FREE DELIVERY
REFURBISHED STOCK WITH FULL 2 YEAR WARRANTY
Select:
Key features
  • Refurbished stock with full 2 year warranty
  • Fully tested grade A condition, external packaging may have some minor cosmetic damage
  • Works with all broadband providers
Product codes
Refurbished stock with full 2 year warranty. Fully tested grade A condition, external packaging may have some minor cosmetic damage.
Superfast, super-reliable Wi-Fi for every room
Two discs, Wi-Fi everywhere
Designed specifically for flats and smaller homes with 1-2 bedrooms, BT's Whole Home Wi-Fi Twin Pack delivers superfast, super-reliable Wi-Fi for every room. Two brilliant discs create a complete Wi-Fi network. Eliminates deadspots and gets you connected on multiple devices, everywhere in your home.
Wi-Fi at its finest
Whole Home Wi-Fi comes with an app to give you complete control. It helps you find the best location for each disc during set up, shows who is connected and even lets you pause the internet for some time offline.
The technical bit
Whole Home Wi-Fi is an "intelligent self-configuring wireless network". That means it knows where you and your devices are and when to automatically switch them from one disc to another to give you the strongest and fastest connection it can. The two discs might be small, but their four built-in 2.4GHz and 5GHz antennas pack a mighty AC2600 wireless punch and incorporate the latest in Wi-Fi security.
Stay connected
Two discs create a complete Wi-Fi network, eliminating deadspots and making sure you're connected on every device, everywhere in your home.
Complete control
Use the app for simple set up, see who's online and even pause the internet.
Super smart
Our intelligent Wi-Fi technology automatically connects you to the fastest and strongest signal as you move from room to room.
What's in the box?
  • 2 x 11ac Dual-Band Wi-Fi Discs
  • 2 x Power Supply Units
  • Ethernet Cable
  • Quick Start Guide
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
BT Refurbished Whole H...
