BT Whole Home Wi-Fi – Twin Pack
FREE DELIVERY
RRP £149.99
£124.99
More than 50 in stock
Delivery:
Standard: 1-3 working days
Express: Delivered on Monday
Express Delivery:
  • 00 h
  • 00 m
  • 00 s
Key features
  • Connect the discs to your Wi-Fi connection for complete Wi-Fi coverage throughout your home
  • Eliminates deadspots
  • Works with all broadband providers
  • Pause the Internet and see who is online with the Whole Home Wi-Fi app
  • Not compatible with Complete WiFi (Black Discs)
  • Type: Whole Home Wi-Fi
  • Connectivity: Wired, Wireless
  • Speed: 1700Mbps
  • Antennas: 4
  • Stock Status: In Stock,
    Used stock also available below
Product codes
Documents
Superfast, super-reliable Wi-Fi for every room
You don’t need to have broadband with BT to use Whole Home Wi-Fi. Just connect the discs to your existing router or hub using the app and you’ll have wi-fi all around your home in minutes.
Two discs, Wi-Fi everywhere
Designed specifically for flats and smaller homes with 1-2 bedrooms, BT's Whole Home Wi-Fi Twin Pack delivers superfast, super-reliable Wi-Fi for every room. Two brilliant discs create a complete Wi-Fi network. Eliminates deadspots and gets you connected on multiple devices, everywhere in your home.
Wi-Fi at its finest
Whole Home Wi-Fi comes with an app to give you complete control. It helps you find the best location for each disc during set up, shows who is connected and even lets you pause the internet for some time offline.
The technical bit
Whole Home Wi-Fi is an "intelligent self-configuring wireless network". That means it knows where you and your devices are and when to automatically switch them from one disc to another to give you the strongest and fastest connection it can. The two discs might be small, but their four built-in 2.4GHz and 5GHz antennas pack a mighty AC2600 wireless punch and incorporate the latest in Wi-Fi security.
Stay connected
Two discs create a complete Wi-Fi network, eliminating deadspots and making sure you're connected on every device, everywhere in your home.
Complete control
Use the app for simple set up, see who's online and even pause the internet.
Super smart
Our intelligent Wi-Fi technology automatically connects you to the fastest and strongest signal as you move from room to room.
What's in the box?
  • 2 x 11ac Dual-Band Wi-Fi Discs
  • 2 x Power Supply Units
  • Ethernet Cable
  • Quick Start Guide
Warranty 3 Year Warranty
Resources
The following resources are available for the BT Whole Home Wi-Fi – Twin Pack
Buy used stock
What is used stock?
Item condition
Accessories
Packaging
Functional
Software
Manuals
product
Customer return - item has been used but is in excellent condition
Ref: D543 042729
£116.14
product
Ref: D543 042729
Accessories
Packaging
Functional
Software
Manuals
£116.14
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
BT Whole Home Wi-Fi –...
£124.99
