Our most powerful solution for ultrafast HD streaming and gaming all around your home with any broadband provider
The ability to upload and download at the same time means faster speeds and less buffering or congestion, especially in busier homes.
Catching up on your shows? Gaming and live TV services benefit as overall speed improves and latency reduces across the network.
For PS5 gamers or those with compatible devices, wi-fi 6 means much faster game downloads. Initial connections with friends and opponents online will also improve.
Tri-band technology pushes faster, stronger wi-fi to every corner of your home
The third high-speed channel you get with tri-band allows more devices to connect, and do more at the same time.
Perfect for bigger families or homes with lots of users streaming content or gaming, all at the same time.
Now you can have multiple users streaming TV, films, music and games on any device, in any room, with no dead spots or drop-outs.
Whole Home Wi-Fi 6 coverage
Standard router coverage
Wi-fi 6 is much faster and more reliable than wi-fi 5, offering speeds of up to 1200Mbps, that’s 40% more than wi-fi 5.
Wi-fi 6 in the discs will work together with wi-fi 6 enabled devices to connect only when they need to, thus saving battery life.
Wi-fi 6 allows for simultaneous uplink and downlink which allows discs to transmit to multiple devices at once.
Wi-fi 6 increases the simultaneous device handling capability by up to 4x more than wi-fi 5.
Wi-fi 6 offers increased bandwidth. This means that ultrafast speeds are pushed even further as uploading doesn’t slow traffic or clog capacity.
Wi-fi 6 has WPA3 technology built in. Enhanced encryption means your data is better protected.
Product Description | BT Mini Whole Home Wi-Fi 6 - radio access point - Wi-Fi 6 | Device Type | Radio access point | Packaged Quantity | 3 (specifications are for single item) | Form Factor | External | Data Link Protocol | IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, IEEE 802.11ax (Wi-Fi 6) | Frequency Band | 2.4 GHz (1 band) / 5 GHz (2 bands) | Performance | Maximum data rate (2.4 GHz): 574 Mbps , Maximum data rate (5 GHz): 4.8 Gbps | Power | AC 230 V (50 Hz) | Dimensions (WxDxH) | 18.2 cm x 7.1 cm x 18.2 cm | Weight | 468 g |
General | |
Width | 18.2 cm |
Depth | 7.1 cm |
Height | 18.2 cm |
Weight | 468 g |
Networking | |
Connectivity Technology | Wireless |
Features | Roaming function, Wi-Fi Protected Setup (WPS), reset button, band steering, Backhaul Technology, 2x2 MIMO technology, 4x4 MIMO technology |
Encryption Algorithm | AES, WPA, WPA2, WPA3 |
Compliant Standards | IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11k, IEEE 802.11ac, IEEE 802.11v, IEEE 802.11ax |
Aerial | |
Antenna | Internal |
Expansion / Connectivity | |
Interfaces | 2 x 1000Base-T - RJ-45 |
Miscellaneous | |
Cables Included | 1 x network cable |
Power | |
Power Device | External power adapter |
Voltage Required | AC 230 V (50 Hz) |
Power Consumption Operational | 11.4 Watt |
Dimensions & Weight (Shipping) | |
Shipping Width | 23.35 cm |
Shipping Depth | 20.5 cm |
Shipping Height | 26 cm |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 45 °C |
Humidity Range Operating | 10 - 90% |
The following resources are available for the BT Whole Home Wi-Fi 6 - Three Discs
