BT Whole Home Wi-Fi Quad Bundle
FREE DELIVERY
BUNDLES
WORKS WITH ANY BROADBAND SERVICE PROVIDER
Select:
Key features
  • Works with any broadband provider
  • Four discs providing complete Wi-Fi coverage throughout your home
  • Compatible with all broadband providers
  • Complete control over usage – switch the Internet on and off or see who is online through the Whole Home Wi-Fi app
  • Connects to the strongest disc automatically ensuring the best possible connection
  • Not compatible with Complete WiFi (Black Discs)
Product codes
Superfast, super-reliable Wi-Fi for every room
Works with all broadband providers
You don’t need to have broadband with BT to use Whole Home Wi-Fi. Just connect the discs to your existing router or hub using the app and you’ll have wi-fi all around your home in minutes.
Four discs, Wi-Fi everywhere
Designed specifically for larger homes with 6+ bedrooms, BT's Whole Home Wi-Fi Quad Pack delivers superfast, super-reliable Wi-Fi for every room. Four brilliant discs create a complete Wi-Fi network. Eliminates deadspots and gets you connected on multiple devices, everywhere in your home.
Wi-Fi at its finest
Whole Home Wi-Fi comes with an app to give you complete control. It helps you find the best location for each disc during set up, shows who is connected and even lets you pause the internet for some time offline.
The technical bit
Whole Home Wi-Fi is an "intelligent self-configuring wireless network". That means it knows where you and your devices are and when to automatically switch them from one disc to another to give you the strongest and fastest connection it can. The two discs might be small, but their four built-in 2.4GHz and 5GHz antennas pack a mighty AC2600 wireless punch and incorporate the latest in Wi-Fi security.
Stay connected
Four discs create a complete Wi-Fi network, eliminating deadspots and making sure you're connected on every device, everywhere in your home.
Complete control
Use the app for simple set up, see who's online and even pause the internet.
Super smart
Our intelligent Wi-Fi technology automatically connects you to the fastest and strongest signal as you move from room to room.
What's in the box?
  • The bundle contains 2x WHW Twin Packs
  • 4 x 11ac Dual-Band Wi-Fi Discs
  • 4 x Power Supply Units
  • Ethernet Cable
  • Quick Start Guide
Product Description BT Whole Home Wi-Fi - radio access point - Wi-Fi 5
Device Type Radio access point
Packaged Quantity 4 (specifications are for single item)
Form Factor External
Data Link Protocol IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band 2.4 GHz, 5 GHz
Dimensions (WxDxH) 16.5 cm x 7.7 cm x 16.5 cm
Weight 415 g
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
