with 100% call blocking and answer machine
An easy to use big button phone that blocks 100% of nuisance calls.
Featuring
1 You need to have a Caller Display service from your network provider for the block nuisance calls feature to work. Charges may apply.
This is the ideal phone for anyone with sight, hearing or dexterity challenges. The big buttons and large screen will ease the frustration of entering numbers incorrectly or misreading messages. It’s hearing aid compatible and you can even boost the volume of your caller’s voice.
You can block calls from an individual number or use the one touch call blocking button if you don’t want to answer a call. Or, if you’ve answered the call, you can press the call blocking button to end the call and add the number to your list of blocked numbers. Over time the phone learns which calls you do and don’t want to take.
Save up to 60 minutes of messages and see how many messages you’ve received clearly on the screen. You can playback your messages privately through the handset or using the handsfree speaker. There’s also an option to playback your messages slowly.
You can save up to 200 contacts and these can be shared between handsets if you buy a multi pack or register extra handsets. Parental control lets you set a PIN to protect calls to mobile and premium rate numbers to prevent any surprises on your bill, useful if you have children or for elderly relatives who may unknowingly dial numbers they don’t need to.
Product Description | BT 4600 Advanced Nuisance Call Blocker Trio - cordless phone - answering system with caller ID + 2 additional handsets - 3-way call capability | Product Type | Cordless phone answering system with caller ID + 2 additional handsets | Total Number of Wireless Handsets | 3 | Cordless Phone Standard | DECT\GAP | Speakerphone | Yes | Call Services | Caller ID, Call Transfer | Display | LCD display - monochrome - Yes | Manufacturer Warranty | 1-year warranty |
General | |
Product Type | Cordless phone answering system |
Additional Handsets Qty | 2 |
Phone Features | |
Caller ID Type | Caller ID |
Max Handset Operating Distance | 50 m |
Max Handset Operating Distance (Outdoor) | 300 m |
Dialer Location | Handset |
Conference Call Capability | 3-way |
Volume Control | Yes |
Ring Tones | 15 |
Polyphonic Ringer | Yes |
Indicators | Visual ringer light |
Additional Functions | Call timer, built-in clock, Alarm |
Phone Memory | |
Phone Directory Capacity | 200 names & numbers |
Answering System | |
Recording Capacity | 60 min |
Display | |
Type | LCD display - monochrome |
Display Location | Handset |
Backlit | Yes |
Miscellaneous | |
Connections | Headset jack |
Placing / Mounting | Table-top |
Included Accessories | Power adapter, 2 phone charging stands |
Dimensions & Weight (Base) | |
Weight | 198.4 g |
Dimensions & Weight (Handset) | |
Width | 6.1 cm |
Depth | 4 cm |
Height | 18.3 cm |
Weight | 141.4 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
The following resources are available for the BT4600 Premium Nuisance Call Blocker - Trio
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
