Buffalo 1TB MiniStation Air 2 Mobile Wireless Storage
Key features
  • The MiniStation Air is sleek and compact, and uses integrated WiFi to create its own hotspot and stream data to and from your Smartphones and tablets.
  • With DLNA, the Buffalo's MiniStation Air also streams to any DLNA-ready device for quick access to up to 1 TB of portable storage. It’s perfect for storing and streaming multimedia content such as movies, music, and photos, and if an internet connection is available it’s also possible to simultaneously stream music or films while surfing the web.
  • Ideal for business travel, vacationers, and anyone who wants to easily access their content
  • Up to 8 connections possible, and up to 3 simultaneous HD streams
  • The HDW-PDU3 has up to 12 hours of battery life for streaming, or, can even double as a smartphone charger with enough capacity to charge two iPhones!
  • Buffalo also offers new re-designed and optimised free mobile apps for iOS and Android. If users want to directly connect the new MiniStation Air to a PC or Mac it’s ready-to-go with SuperSpeed USB 3.0
  • The Buffalo AirStation One-Touch Secure System (AOSS) and Wi-Fi Protected Setup (WPS) provide a quick and easy way to create a secure wireless connection to a host within minutes.
  • Expand the storage capacities of Buffalo’s new MiniStation Air without the hassle of wires, cables, or an internet connection
Product codes
Documents
Buffalo's MiniStation Air 2 (HDW-PDU3 series) is a battery-powered Wireless Hard Drive that enables users to greatly expand their storage capacities without the hassle of wires, cables, or an internet connection.
Buffalo's MiniStation Air 2 uses integrated WiFi to create its own hotspot and stream data to and from your Smartphones and tablets. And, with DLNA, the MiniStation Air 2 also streams to any DLNA-ready device for quick access to up to 1 TB of portable storage. It's perfect for storing and streaming multimedia content such as movies, music, and photos, and if an internet connection is available it's also possible to simultaneously stream music or films while surfing the web.
The HDW-PDU3 has up to 12 hours of battery life for streaming, or, can even double as a smartphone charger with enough capacity to charge two iPhones! The MiniStation Air 2 is sleek and compact, and Buffalo also offers re-designed and optimized free mobile apps for iOS and Android . If users want to directly connect the MiniStation Air 2 to a PC or Mac it's ready-to-go with SuperSpeed USB 3.0.
With integrated WiFi, DLNA, and available capacities of 500 GB or 1 TB, the HDW-PDU3 lets you easily have all your data, wherever you go!
Features and Benefits
  • The MiniStation™ Air 2 is a compact portable storage solution with wireless streaming capabilities: Ideal for business travel, vacationers, and anyone who wants to easily access their content
  • Expand storage capacities without the hassle of wires, cables, or an internet connection
  • Easily connect with WPS or AOSS
  • Features long battery life: up to 12 hours streaming on a single charge
  • Also doubles as a portable battery charger for charging smartphones
  • Includes a USB 3.0 port for fast file transfers when directly connected to any PC or Mac® computer
  • Transfer sizes and data amounts and are no longer limiting
  • More convenience, choices, and enjoyment regarding your movies, music, and photos
  • WPA2 wireless encryption for secure data transfer
  • While wirelessly connected to the MiniStation™ you can also use the internet
  • 3 year warranty
  • HDD Interface SATA
  • Capacities 500 GB, 1 TB
  • Standard Compliance USB 3.0
  • Connector Type USB type A
  • Number of Ports 1
  • Data Transfer Rate 5Gb/s
  • Standard Compliance IEEE802.11/u/ab
  • Transmission Method ODFM, MIMO, DSSS
  • Frequency Range 2.4GHz
  • Transmission Rate 300 Mbps
  • Antenna (TX x RX) 2x2
  • Access Method CSMA/CA
  • Access Mode Infrastructure Mode
  • Security WPA2-PSK (AES, TKIP), WPA-PSK (AES, TKIP), 128/64Bit WEP
  • Mini Station™ Air2 iOS, Android®
  • DLNA Compatible Media Server Music: MP3, WMA, WAV, 3GP, M4A, MP4, LPCM, Ogg Vorbis, FLAC, MP2, AC3, MPA, MP1, AIF, MID, ISMA
  • Photo: JPEG, PNG, TIF, BMP
  • Video: MPEG1, MPEG2, MPEG2-TS, MPEG4, AVI, WMV, VOB, DivX, 3GP, VDR, ASF, MPE, DVR-MS, Xvid, M1V, M4V, WEBM, QT, F4V, ISMV, MKV, MOV
  • Supported OS WiFi: iOS 6 and later, Android® 2.3 and later, Windows 8, Windows® 7, Windows Vista™, Windows® XP, Windows® RT, Mac OS® X 10.6 or later
  • USB: Windows 8/ Windows® 7/ Windows Vista™*/ Windows® XP, Windows® RT, Mac OS® X 10.8/10.7/10.6/10.5 *32/64bit support
  • Dimensions (WxDxH) 84x140x18 mm
  • Weight 255 g
  • Operating Environment Temperature 0-40°C, humidity 10-85% (non-condensing)
  • Battery 3020 mAh
  • Power Supply USB charger, USB 3.0
BUFFALO MiniStation Air 2 - network drive - 1 TB
Network drive
Host Connectivity
USB 3.0 / 802.11b/g/n
Total Storage Capacity
1 TB
8.4 cm x 14 cm x 1.8 cm
255 g
Storage Controller
SATA SATA 3Gb/s
Hard Drive
1 x 1 TB SATA 3Gb/s
802.11b/g/n, USB 3.0
Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista, Apple MacOS X 10.6 or later, Apple MacOS X 10.5, Windows 8, Microsoft Windows RT, Android 2.3 or later, Apple iOS 6.0 or later
3 years warranty
Resources
The following resources are available for the Buffalo 1TB MiniStation Air 2 Mobile Wireless Storage
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Buffalo 1TB MiniStatio...
