Buffalo 1TB MiniStation Extreme USB 3.0 Water & Dust Resi...
Buffalo 1TB MiniStation Extreme USB 3.0 Water & Dust Resistant Portable Hard Drive - Black
£95.70
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • US military grade (MIL-SPEC) shock protection
  • Flex connect USB cable
  • Hardware disk encryption
  • Compact and sleek
  • USB powered
  • Connect and go
  • Form Factor: 2.5"
  • Capacity: 1TB
  • Interface: USB 3.0
  • Stock Status: In Stock
Product codes
MiniStation™ Extreme - The perfect solution for those who often travel with PCs and portable HDDs
BUFFALO’s MiniStation™ Extreme offers high performance USB3.0 portable storage in a compact and sophisticated design. The internal hard drive is encased in a highly shock-resistant body with rubberised elements to protect it from accidental bumps.
The ingenious arrangement of shock protection features meets the U.S. Military Standard MIL-STD-810G, METHOD 516.6, Procedure IV and has passed free-fall drop tests with drops up to 2.3 meters.
Moreover, the USB cable is integrated with the case so you will not be frustrated searching for a cable anymore!
The USB 3.0 interface moves data at rates of up to 5Gbps. This vastly reduces the time needed for data transmission, making it ideal for transferring and sharing videos, large digital photo collections, music files, and other data-intensive digital content. MiniStation Extreme is available with 1TB or 2TB capacities. Both capacities are available in black; 1TB capacity is also available in red or silver.
Highly Shock-Resistant
Buffalo™ gave the HD-PZFU3 a sleek design with an attractive matte finish and Buffalo’s patented shock-proof chassis: U.S. military-grade shock protection helps protect the hard drive from damage, passing 2.3-meter free-fall drop test.
Water and Dust-Resistant
Complies with standard IPX3:
Spraying water from angles up to 60° from the vertical shall have no harmful effect.
Complies with Standard IP5X:
Dust will not interfere with the satisfactory operation.
Want more protection?
Hardware Disk Encryption: 256-bit AES Full Disk Encryption (FDE) protects your data from unauthorised access. This type of encryption has never been broken and governments and businesses place a great deal of faith that it never will be.
Easy Cable Management
Integrated USB3.0 cable snaps to chassis for pack-and-go-portability.
Product Description BUFFALO MiniStation Extreme - hard drive - 1 TB - USB 3.0
Type Hard drive - external (portable) - shock resistant, water resistant, Hardware Full Disk Encryption (FDE), dust-proof, wrap-around USB cable, Apple Time Machine compatible
Capacity 1 TB
Hardware Encryption Yes
Interface USB 3.0
Data Transfer Rate 5.0 Gbps (USB 3.0)
Features Shock resistant, water resistant, Hardware Full Disk Encryption (FDE), dust-proof, wrap-around USB cable, Apple Time Machine compatible, 256-bit AES
Power Source USB bus
Enclosure Colour Black
Dimensions (WxDxH) 9 cm x 14.1 cm x 2.1 cm
Weight 277 g
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Buffalo 1TB MiniStatio...
£95.70
