Buffalo 2TB DriveStation USB 2.0 Desktop Hard Drive
PRICE CRASH! WEEK SPECIAL, WAS £109.99 - SAVE £10!
1 on order, delivery delayed
Key features
  • USB 2.0 Interface
  • Pre-formatted drive for immediate use
  • Easy set-up, no drivers required
  • Connects to USB on any PC or Mac
  • Ships as two versions, UK power supply and EU
  • Available with 1TB or 2TB capacities
Product codes
Documents
Buffalo's DriveStation USB 2.0 Hard Drive HD-LBU2 is an easy to use external hard drive to add additional external storage to any device using a USB port. The DriveStation features a sleek, black glossy chassis that can be positioned vertically or horizontally, adapting to the location it is used in for an efficient use of space.
Get more storage instantly by simply plugging in Buffalo's DriveStation™ USB 2.0 Hard Drive HD-LBU2 to a PC or Mac via a USB port. The Buffalo DriveStation™ is a quiet external hard drive in a black glossy chassis that looks stylishly sleek whether you place it upright or flat. Its adaptive design allows efficient use of space.
Auto functions
The DriveStation™'s auto installation and auto power on/off features make it easy to use, and provide an economical solution where you can quickly store, access, and transfer files, digital images, documents, and backups.
  • Compatible Interfaces: USB 2.0 Interface - connects to USB on any PC or Mac
  • Pre-formatted drive: Ready to use, anytime
  • Connect and go: Easy to use and setup, simply plug it into the USB and play; no drivers required
  • USB Interface: Standard Compliance USB 2.0, Connector Type USB Type B, Number of Ports1, Data Tansfer Rates Max. 480Mbps (USB 2.0 Mode)
  • Dimensions (WxHxD) 38.7 x 122.6 x 189mm
  • Weight 950g
  • OS SupportWindows®7 (32bit, 64bit), Windows® Vista™(32bit, 64bit), Windows® XP, Mac OS 10.4 or later
Product Description BUFFALO DriveStation - hard drive - 2 TB - USB 2.0
Type Hard drive - external (desktop)
Capacity 2 TB
Interface USB 2.0
Power Source Included AC adapter
Enclosure Colour Glossy black
Dimensions (WxDxH) 3.9 cm x 18.9 cm x 12.3 cm
Weight 0.95 kg
Localisation United Kingdom
Resources
The following resources are available for the Buffalo 2TB DriveStation USB 2.0 Desktop Hard Drive
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
