Buffalo 2TB DriveStation USB 3.0 3.5" Desktop External H...
Buffalo 2TB DriveStation USB 3.0 3.5" Desktop External Hard Drive
£69.33
Select:
Delivery:
Standard: 1-3 working days
Key features
  • Eco-friendly
  • SuperSpeed USB 3.0
  • Form Factor: 3.5"
  • Capacity: 2TB
  • Interface: USB 3.0
  • Stock Status: In Stock
Product codes
Buffalo's DriveStation (HD-LCU3) is an easy-to-use, economical, and silent solution, that enables users to quickly store, access, and transfer files, digital images, documents, and back-ups. Just plug it in to almost any device with a USB port and Buffalo's DriveStation will instantly expand your storage. The HD-LCU3 features a sleek chassis, that can be positioned vertically or horizontally and has specially-designed interior bumpers to help ensure near-silent operation. Together with eco-friendly auto power on/off, Buffalo's DriveStation is a smart choice for any user.
Product Description BUFFALO DriveStation HD-LCU3 Series - hard drive - 2 TB - USB 3.0
Type Hard drive - external (desktop) - Silent HDD, ECO, Apple Time Machine compatible, software encryption, power management support
Capacity 2 TB
Form Factor 3.5"
Interface USB 3.0
Data Transfer Rate 5.0 Gbps (USB 3.0)
Features Silent HDD, ECO, Apple Time Machine compatible, software encryption, power management support
Power Source Included AC adapter
Dimensions (WxDxH) 3.9 cm x 18.7 cm x 12 cm
Weight 1 kg
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
Buffalo 2TB DriveStati...
£69.33
