Buffalo 2TB DriveStation Velocity USB 3.0 External HDD Hardwa...
Buffalo 2TB DriveStation Velocity USB 3.0 External HDD Hardware Encryption
£71.95
Delivery:
Standard: 1-3 working days
Key features
  • SuperSpeed USB 3.0: The USB 3.0 interface moves data at rates
  • of up to 5 gigabytes per second , ideal for video and other dataintensive
  • digital content
  • TurboPC EX utility: TurboPC EX adds more performance to
  • Buffalo's TurboPC with TurboCopy performance and copy
  • enhancement utility for Windows. Now saving, copying, and
  • transferring files is even faster
  • High speed 7,200 RPM hard disk: The disk reads and writes
  • data faster, so you spend less time waiting when transferring and
  • saving files
  • Hardware Disk Encryption: 256-bit AES Full Disk Encryption (FDE)
  • protects your data from unauthorised access on Windows PCs
  • Back Up Your Files: Buffalo's Backup Utility automatically backs up
  • your Windows PC, protecting your data
  • RAMDISK virtual disk utility: The Windows RAMDISK utility
  • creates a small "virtual hard disk" using your computer's RAM
  • (random access memory)
  • Form Factor: 3.5"
  • Capacity: 2TB
  • Interface: SuperSpeed USB
  • Stock Status: In Stock
Product codes
Documents
SuperSpeed USB 3.0 hard disk drive
DriveStation™ Velocity is the perfect solution for those who need to transfer files quickly and easily. The amazing speed performance comes from a combination of a more efficient improved USB 3.0 interface, Buffalo's enhanced TurboPC EX data transfer and copy utility and a 7,200 RPM drive. With USB 3.0, digital content transfers at speeds of up to 5Gbps*. If you haven't moved up to USB 3.0 yet - DriveStation™ Velocity is backward compatible with USB 2.0.
The unit is also optimal for users who want to restrict access to their personal drive when on a shared computer or network. Powerful yet easy-to-use security options include automatic hardware encryption that protects your data, with no loss of performance.
Features and Benefits
  • SuperSpeed USB 3.0: The USB 3.0 interface moves data at rates of up to 5 gigabytes per second*, ideal for video and other dataintensive digital content
  • TurboPC EX utility: TurboPC EX adds more performance to Buffalo's TurboPC with TurboCopy performance and copy enhancement utility for Windows. Now saving, copying, and transferring files is even faster.
  • High speed 7,200 RPM hard disk: The disk reads and writes data faster, so you spend less time waiting when transferring and saving files
  • Hardware Disk Encryption: 256-bit AES Full Disk Encryption (FDE) protects your data from unauthorised access on Windows PCs
  • Back Up Your Files: Buffalo's Backup Utility automatically backs up your Windows PC, protecting your data
  • RAMDISK virtual disk utility: The Windows RAMDISK utility creates a small "virtual hard disk" using your computer's RAM (random access memory)
  • eco Manager: Eco minded power management tool for Windows regulates power usage, conserving energy and battery consumption
  • SuperEco: saves power consumption during stand-by mode by Auto Power OFF
  • SecureLock Manager: Easy software simplifies access for you while keeping others out on Windows PCs
  • Plug & Play Connectivity: Connecting and using the drive is simple-just plug it in to any USB port on a computer or other device you're connecting to. No need to install any drivers and no confusing settings.
  • Fully backwards compatible with USB 2.0: No adjustments are needed, just plug into any USB 2.0 port
  • 2-Year Warranty
Product Description BUFFALO DriveStation Velocity - hard drive - 2 TB - USB 3.0
Type Hard drive - external (desktop) - Hardware Full Disk Encryption (FDE), automatic backup
Capacity 2 TB
Hardware Encryption Yes
Interface USB 3.0
Data Transfer Rate 5.0 Gbps (USB 3.0)
Spindle Speed 7200 rpm
Features Hardware Full Disk Encryption (FDE), automatic backup, 256-bit AES
Dimensions (WxDxH) 3.9 cm x 18.9 cm x 12.3 cm
Weight 0.95 kg
Localisation Europe
Resources
The following resources are available for the Buffalo 2TB DriveStation Velocity USB 3.0 External HDD Hardware Encryption
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Buffalo 2TB DriveStati...
£71.95
