Buffalo 2TB MiniStation 'Safe' Portable HD flat prote...
Buffalo 2TB MiniStation 'Safe' Portable HD flat protection - Black
£86.68
Select:
Delivery:
Standard: 1-3 working days
Key features
  • Buffalo gave the HD-PNFU3 a sleek design with an attractive matte finish and Buffalo’s patented shock-proof chassis.
  • The second protection comes from Buffalo’s new Lock-and-Go feature allowing both PC and Mac users to quickly and easily password-protect their data. The MiniStation Safe will stay locked until the correct password is re-entered – no matter where you take it
  • With Buffalo Tools’ SecureLockMobile PC users can software encrypt their device and have the option to keep both encrypted and unencrypted data on the same drive. Files are password protected once moved into an encrypted container and users can choose between 128 or 256 bit encryption (default value is 256 bit).
  • The difference: 128 bit encryption could theoretically be cracked in a billion years; and 256 bit would take even longer – using a super computer! This type of encryption has never been broken and governments and businesses place a great deal of faith that it never will be
  • Buffalo’s MiniStation Safe occupies minimal space and offers USB 3.0 bus-powered mobile storage for your data and for your on-the-go lifestyle. It works with PC and Mac, so you can access your files from whichever computer you are on, even while on the go.
  • SuperSpeed data transfer with USB 3.0
  • USB powered, no additional power supply needed
  • Plug-n-Play ready for immediate use
  • Comes with Buffalo Tools’ eco Manager feature to conserve energy
  • Form Factor: 2.5"
  • Capacity: 2TB
  • Interface: USB 3.0
  • Stock Status: In Stock
Product codes
Buffalo's new MiniStation Safe (HD-PNFU3 series) is a slim, SuperSpeed USB 3.0, portable hard drive that comes in a patented shock-proof chassis and features Buffalo's new Lock-and-Go feature - thereby protecting your data in two important ways!
Firstly, Buffalo gave the HD-PNFU3 a sleek design with an attractive matte finish and Buffalo's patented shock-proof chassis. The second protection comes from Buffalo's new Lock-and-Go feature allowing both PC and Mac users to quickly and easily password-protect their data. The MiniStation Safe will stay locked until the correct password is re-entered - no matter where you take it!
Want more protection? With Buffalo Tools' SecureLockMobile PC users can software encrypt their device and have the option to keep both encrypted and unencrypted data on the same drive. Files are password protected once moved into an encrypted container and users can choose between 128 or 256 bit encryption (default value is 256 bit). The difference: 128 bit encryption could theoretically be cracked in a billion years; and 256 bit would take even longer - using a super computer! This type of encryption has never been broken and governments and businesses place a great deal of faith that it never will be.
The new HD-PNFU3 MiniStation Safe brings you the Buffalo quality you know and trust in a small, attractive, and secure package. MiniStation Safe is available with 1TB, or 2TB capacities. All capacities are available in black; 1TB capacity is also available in red.
Product Description BUFFALO MiniStation Safe - hard drive - 2 TB - USB 3.0
Type Hard drive - external (portable) - shock resistant, software encryption, power management support
Capacity 2 TB
Interface USB 3.0
Data Transfer Rate 5.0 Gbps (USB 3.0)
Features Shock resistant, software encryption, power management support, 256-bit AES, 128-bit AES
Power Source USB bus
Enclosure Colour Black
Dimensions (WxDxH) 7.95 cm x 11.5 cm x 2.15 cm
Weight 240 g
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Buffalo 2TB MiniStatio...
£86.68
