Buffalo's DriveStation (HD-LCU3) is an easy-to-use, economical, and silent solution, that enables users to quickly store, access, and transfer files, digital images, documents, and back-ups. Just plug it in to almost any device with a USB port and Buffalo's DriveStation will instantly expand your storage. The HD-LCU3 features a sleek chassis, that can be positioned vertically or horizontally and has specially-designed interior bumpers to help ensure near-silent operation. Together with eco-friendly auto power on/off, Buffalo's DriveStation is a smart choice for any user.
Product Description | BUFFALO DriveStation HD-LCU3 Series - hard drive - 3 TB - USB 3.0 | Type | Hard drive - external (desktop) - Silent HDD, ECO, Apple Time Machine compatible, software encryption, power management support | Capacity | 3 TB | Form Factor | 3.5" | Interface | USB 3.0 | Data Transfer Rate | 5.0 Gbps (USB 3.0) | Features | Silent HDD, ECO, Apple Time Machine compatible, software encryption, power management support | Power Source | Included AC adapter | Dimensions (WxDxH) | 3.9 cm x 18.7 cm x 12 cm | Weight | 1 kg |
General | |
Device Type | Hard drive - external (desktop) |
Capacity | 3 TB |
Internal Drive Interface | SATA 3 Gb/s |
Width | 3.9 cm |
Depth | 18.7 cm |
Height | 12 cm |
Weight | 1 kg |
Performance | |
Interface Transfer Rate | 5.0 Gbps (USB 3.0) |
Expansion & Connectivity | |
Interfaces | 1 x USB 3.0 - 10 pin Micro-USB Type B |
Compatible Bay | 3.5" |
Power | |
Power Device | Power adapter |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Consumption | 18 Watt (maximum) |
Software & System Requirements | |
OS Required | Microsoft Windows 7, Microsoft Windows Vista, Apple MacOS X 10.7 or later, Windows 8, Apple MacOS X 10.5 - 10.8, Windows 8.1, Windows 10 |
Miscellaneous | |
Cables Included | 1 x USB 3.0 cable - external |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 20 - 80% (non-condensing) |
